Weird Radiator Leak
Old Oct 27, 2014 | 09:46 PM
golgafrinch's Avatar
Default Weird Radiator Leak
Anybody seen this one? And does this mean a new radiator for me?
It must be just a tiny little pinhole or a crack. I can't see any holes. It leaks like this when the engine is cooling down. Not when it's hot as far as I can tell.
Took me forever to find.
'04 Disco II
Old Oct 28, 2014 | 05:15 AM
acamato's Avatar
<p>Its from over tightening the screw that's is next to the crack. I believe that it cannot be repaired and has to be replaced.</p>
Old Oct 28, 2014 | 07:36 AM
drowssap's Avatar
ebay radiator $150 and shorter screws
Old Oct 28, 2014 | 03:38 PM
Awww man....Thanks fellas!
Old Oct 28, 2014 | 04:18 PM
04duxlr's Avatar
You can pull the screw out and stuff the hole with RTV then install the screw again for now. When you install the new radiator, don't use screws for the shroud. Put it on with cable ties: https://landroverforums.com/forum/di...upgrade-59523/
Old Jan 9, 2015 | 06:11 PM
Flyhighdp's Avatar
Exclamation same prob!
'04 Disco II
I have the exact same problem!! what did you end up doing to resolve this mess?
Old Jan 9, 2015 | 10:21 PM
For a temporary fix, I used JB plastic weld for the crack on top. And then shot some orange rtv in the screwhole. I also put a few washers to keep the screws from bottoming out. Worked like a charm. But I did end up getting a new radiator for a permanent fix. I'm installing it tomorrow.
I still haven't decided whether to use the washers or go with the "sophisticated" zip tie solution.
On my phone right now or I would give credit and appropriate links.
Old Jan 10, 2015 | 06:36 AM
duxd2's Avatar
I posted about my zip-tie fix (I had to change my user name) right after I did it and it's still going strong 3 1/2 years later. By the way, I'm convinced the cracks don't come from the screws bottoming out, it's from the lateral stress caused by the screw threading into the hole. My radiator cracked adjacent to the screw hole as if it had been split by a wedge.
Old Jan 13, 2015 | 02:57 PM
Thanks for the inspiration. I put a new radiator in yesterday and didn't even thing about putting the screws in it. Just the zip ties.
Old Jan 13, 2015 | 08:53 PM
driftology's Avatar
I used a plastic welder last year on mine. So far so good.
