What is this?
What is this?
Ok so my blower motor stopped working. I took the motor out and tested it and it works, I testedthe two relays next to it and they work. I purchased a new control unit( dash buttons) and that didn't fix it. Finally I found this part that looks like it had resistors in it. So here are my questions:
1) what is this?
2) will it cause my blower to not work?
3) what size resistors can I solder back in it?
4) what does the inner schematic look?
[IMG]http://img.photobucket.com/albums/v674/phidelt583/i
mage-1.jpg[/IMG]
1) what is this?
mage-1.jpg[/IMG]
All resistors are color coded. You can type in the color of the bands and get the ohm rating. Then plug in your vom meter and check to see if it is reading right. You can always just swap it out, or try a wide range variable resistor that lets you dial it in. (Radio shack dorks will love you for asking).
