what is code p1590 ?
I had a autologic read my faults today. It read P1590 And the tech said it was abs ecu failure. He also sadi the ecu may have damaged some wiring. I am wondering what i should do next. I was going to spend the money on an ABS modulator Kit for 800.00 from rover parts but i do not want to purchase the wrong part. I have already tried the cheap fix ( shuttle valve kit) and that did not work .The tech says i need an ECU ..Is the ECU on the computer side of the MOdulator. Would appreciate any helpCaleb
RE: what is code p1590 ?
The cheap shuttle valve kit never works, you must use the expensive one.
DiscoMike knows more about this than I do, but I highly doubt that you need a new ECU. |
http://www.troublecodes.net/landrvr/
Gives all the codes for the Land Rover OBDII system. I found it pretty helpful |
1590 is a rough road/ABS fault that normally will also show up when the ABS is having problem with the lights coming on and off or on all the way.
It can be clear with a proper scanner and is not being caused by any other ABS part. |
Originally Posted by Disco Mike
(Post 88771)
It can be clear with a proper scanner and is not being caused by any other ABS part. I had to re-register today whats up with that? Thanks man, Jeff |
The 1590 code is a Rough Road/ABS fault only indicating the the 3 Amigos are on or come on go. Fix you brakes and then you can clear the code.
(Post 88771)
