What is considered normal RPM range for city/highway speeds?
Old 07-18-2018, 02:57 PM
TRIARII's Avatar
Default What is considered normal RPM range for city/highway speeds?
I get the impression that my RPM'S are above average when cruising on the highway at 65-70 MPH. Or maybe Im just being paranoid? Anyways what are the acceptable RPM range for highway speeds?
Old 07-18-2018, 03:22 PM
Received 1,151 Likes on 796 Posts
Looks about right to me
Old 07-18-2018, 03:45 PM
Bulax99's Avatar
I agree. I think we have become so used to today’s cars running 2000rpm at 100mph it’s alarming when we get in an older 4 or 5 speed. I bought a 99 Land Cruiser last year and swore that the clutch plates were going to slice through the transmission tunnel and severe my legs when I realized I was going 75mph and 3,200rpm. Redline is like 5,600 on that truck.
Old 07-18-2018, 05:18 PM
Jeff Blake's Avatar
D2's with the right gearing should be around 2700rpm @ 70mph in top gear
Old 07-18-2018, 08:58 PM
Best4x4's Avatar
Received 2,283 Likes on 1,682 Posts
Yep at 70-75MPH I'm sitting just over 2,500RPM's. In my 99, 02, and 04.
Old 07-19-2018, 12:40 AM
Dave03S's Avatar
With OG 255/55r16's I was at 2750 at 70... With the current tires it says 2500 at 70. Of course neither the speedo or the odo are correct according to GPS...
You really don't know how fast you are going until you use a few GPS apps on your smart phone or some outside measurement method like timing how long it takes between mile markers on a long straight stretch.
Once you know how fast your are actually going then you can see what the RPM's are at when you are actually driving 70 rather than just when your speedo says you are. Of course this is easier if you pick a long straight highway that will allow you to go 60 mph in one minute... for those that are mathematically challenged.
Old 07-19-2018, 01:09 AM
Trevor smith's Avatar
Default New to land rover discovery 2
IV same as above when driving it changes at 3000 rpm when pulling my caravan found it hard to get over 60 kph why can anyone help
Old 07-19-2018, 02:15 AM
The Deputy's Avatar
Received 1,204 Likes on 860 Posts
Need more info, and if you're from Kildare, Ireland...l'd assume we're talking diesel? And, l assume you are saying this issue only occurs while towing?
Brian.
Old 07-19-2018, 07:27 AM
Thanks for getting back to me .it's a 2.5 diesel and u think it's slow to change all the time . But very bad when I have it hooked up to caravan
Old 07-22-2018, 09:52 AM
The Deputy's Avatar
https://www.aulro.com/afvb/
Might get more info about diesel performance on this site above. More diesel folks in Australia.
Back on topic...
2001 Dll - 265/75-16's ...70 mph...2300 rpm. 75 mph...2500 rpm. Miles per hour verified, not odometer reading.
Brian.
Quick Reply: What is considered normal RPM range for city/highway speeds?
