What do you think?
The Jeep guys have been doing this for years, they use a multitude of vents from a lot of different cars, there is also some aftermarket ones that can be found in the back of a 4wheeler magazine. I used a couple of vents from a plymouth laser and added some small dc fans underneath to expel the hot air. It lowered the temp by at least 25 degrees which while wheeling can make a big difference. The Jeep was not as polished as my Rovers are so I would not do it to mine in present condition.
At least you are thinking out of the box.
Hey...it's your Disco, do what you want!
BUT...if I were to do it, I'd do it in flat-black in conjunction with this:
http://www.roversnorth.com/store/p-1...scovery-i.aspx
The scoop would be far-less noticeable, but then again, the flat black would probably grab more heat...go figure!
do they make any sort of hood scoop for a disco? I'm just trying to keep the temp down on long drives. I am very much considering the blackout kit (need to decide between paint or decal though, I am watching the other thread) Yes its a spare off my suby, thought if it wasn't getting used might as well take a look.
However looking now it does look far to small for such a big hood.
what temps are you running at?
