What front driveshaft do I have?
Old 06-03-2021 | 01:10 PM
DanJC's Avatar
Originally Posted by whowa004
I would not buy that Lucky8 shaft. Find a local driveshaft shop and take your stock on in so they can reuse the mounting ends and have them build one or look on ebay.
It seems to be well-regarded generally. It does say on their site not to use it on lifted trucks, but mine is not.
Old 06-03-2021 | 01:16 PM
whowa004's Avatar
Mine was lifted when it failed but that wasn't the plan for the truck when I bought the shaft. It failed less than 2k (shaft had less than 5k miles on it in total) miles after being lifted on a cross country trip from CO to VA somewhere in KY. removed it before it grenaded and locked the CDL and we kept on trucking.
For the money I think a local option or the A1 option on ebay is a better option, it's mentioned in the other driveshaft thread that is going on right now.
Old 06-03-2021 | 04:05 PM
frostythor's Avatar
Strange in the manual they are denoted as Propeller shaft, thats Prop shaft just as as it says, and it was made in the UK
item No #,4, #5
just out of curiosity which "Universe " are you talking about, far far away................
Old 06-03-2021 | 05:25 PM
rhyslegge's Avatar
The first time that I replaced the front prop shaft on a disco, I replaced all of the joints and centering ball myself, I will not do that again! I would highly recommend the BPU shaft as not only are the u-joints greasable, the centering ball on the hookes joint has a grease fitting as well. You won't need to needle-grease the ball thru the seal or dissassemble to lube the centering ball. Down side is that it is pricey.
Rhys L.
DanJC (06-03-2021)
Old 06-03-2021 | 05:51 PM
DanJC's Avatar
Thanks for the info.
What I’m wondering is to what extent the a hyper-greased, heavy duty drive shaft is needed vs just a serviceable one like Lucky8.
Like is it going from 95% to 99% for 2x the price?
Old 06-03-2021 | 07:30 PM
mollusc's Avatar
Pay attention. I said ALMOST universally. And that the term was used that way only in the UK.
Old 06-04-2021 | 03:52 AM
frostythor's Avatar
True... Mollusc, but then then Discovery was made in the UK so the correct term applies........... does it not, bit like a boot and a trunk,
Old 06-04-2021 | 05:48 AM
JUKE179r's Avatar
Tomayto … tomahto… Pip Pip old chap...
I always get grief from the Brits when I mention rocker cover then I get corrected that it is a valve cover.
Or when I mention cigarette lighter in the Land Rover but the Brits call it a cigar lighter.
Old 06-04-2021 | 05:59 AM
frostythor's Avatar
Less of the Old Chap.............im only 70
Old 06-04-2021 | 07:08 AM
mollusc's Avatar
Exactly. Different term for the same part. So you can use either one. It's not helpful to say "it's NOT a driveshaft."
I'm from New Zealand. We use the two terms in the complete opposite way: prop shafts or half-shafts run from the diff to the wheels, and a driveshaft runs lengthwise along the vehicle. However, since the OP is in the US and is looking to buy a part, it seems best to use the term that he's going to have the most luck with when he uses it in context.
As for rocker/valve cover.... what if you're talking about a OHC engine and there are no rockers?
Quick Reply: What front driveshaft do I have?
