What the heck did I do now?
I changed my suspension and now it idle's rough?? I had to remove the air intake to get the shock tower out on the drivers front side, now I'm getting a check engine light after putting it back together with error codes:
P0103 Mass Air Flow Sensor High Out of Range Fault P0112 Air Temperature Sensor Low Out of Range Fault Any ideas? |
Make sure your connection to the MAF sensor is plugged in all the way.
X2, had the same issue my first air filter change.
Weird, I reseated that first and was still getting the check engine light and codes afterwards. But, after letting sit for 30 minutes off, started it up and no light, no codes! I guess that was it. Thanks.
MAF and IAT are inside same unit on a D2. You are probably overdue on roasting some raw meat to honor the Rover gods who watch your progress.
