What the heck did I do now?
Old Apr 20, 2013 | 03:26 PM
caymandrew's Avatar
Default What the heck did I do now?
I changed my suspension and now it idle's rough?? I had to remove the air intake to get the shock tower out on the drivers front side, now I'm getting a check engine light after putting it back together with error codes:
P0103 Mass Air Flow Sensor High Out of Range Fault
P0112 Air Temperature Sensor Low Out of Range Fault
Any ideas?
Old Apr 20, 2013 | 03:44 PM
ralphobell's Avatar
Make sure your connection to the MAF sensor is plugged in all the way.
Old Apr 20, 2013 | 04:14 PM
Rover_Hokie's Avatar
X2, had the same issue my first air filter change.
Old Apr 20, 2013 | 05:19 PM
caymandrew's Avatar
Weird, I reseated that first and was still getting the check engine light and codes afterwards. But, after letting sit for 30 minutes off, started it up and no light, no codes! I guess that was it. Thanks.
Old Apr 20, 2013 | 10:08 PM
MAF and IAT are inside same unit on a D2. You are probably overdue on roasting some raw meat to honor the Rover gods who watch your progress.
range_time
May 6, 2010 05:11 PM
ljdiscovery
Feb 24, 2009 04:22 PM
feitinger
Jan 27, 2009 02:43 PM
ArizonaDiscovery
May 4, 2007 02:26 PM
suparice
Jul 12, 2006 03:59 PM
