What is this leaking...Anyone?
This connector is located on the passenger side, along the top of the chassie near the transfer case. Its connected to a rectangular box marked "tank" and "purge". I don't know what it is. It apparently only leaks when the heater is running. I thought I smelled coolant a couple of days ago but I'm not sure. I checked the collant level and it was in fact low. I haven't used the heater since and it hasn't leaked anymore. Can anyone tell me? The picture I intended to add did not show up in the preview. Perhaps it will appear in the post.
[IMG]local://upfiles/8289/CDE0A15B53C44ADAAB426E1619B53022.jpg[/IMG]
RE: What is this leaking...Anyone?
That is part of your EVAP system, "tank" is the fuel tank, "purge" is the carbon canister.
The carbon canister is what catches all the gas vapor from inside your gas tank, then turns the vapor into liquid and returns it to the gas tank.
Heater on or off should make no difference.
Is your check engine light on?
Thank you for the quick response. The heater may be coincidental. The check engine light has not come on. Is it possible that fluid from the transfer case is leaking and simply being slung on this hose connector? I smelled of the fluid and really couldn't smell anything. The edge of the leak is right on the connector so I concluded that it was the hose. Many Thanks.
