What are these for?
1 Attachment(s)
These hose nipples are under the Throttle Body. Nothing is hooked to them and I was wondering what they are for.
throttle body heater to keep the butterfly from freezing open
Living where you do, I wouldn't worry about reinstall the hoses, you are not going to be freezing up.
Just curious, is there any advantage to bypassing the throttle body in warm climates? Would doing so bring down temps or raise them?
Originally Posted by Charlie_V
(Post 529381)
I would probably fix it. Nashville routinely gets below freezing from time to time in the winter. Somebody has bypassed it because was leaking. You need this to fix the leak Throttle Body Heater Plate Kit (Genuine Part # MGM000010) | Land Rover And Range Rover Fuel System Parts then re connect the hoses
Originally Posted by 94svt50
(Post 529410)
from your recovery tank
I'm in the middle of the Blue Ridge Mountains in VA and I have mine bypassed. I drove it below -15 last year and it never froze a lick. I'd say don't worry too much about it.
Originally Posted by Alex_M
(Post 529522)
