What are these for?
Old Aug 3, 2015 | 11:46 AM
Southern Bawb's Avatar
Default What are these for?
These hose nipples are under the Throttle Body. Nothing is hooked to them and I was wondering what they are for.
Old Aug 3, 2015 | 11:50 AM
drowssap's Avatar
throttle body heater to keep the butterfly from freezing open
Old Aug 3, 2015 | 11:55 AM
Living where you do, I wouldn't worry about reinstall the hoses, you are not going to be freezing up.
Old Aug 3, 2015 | 12:27 PM
Charlie_V's Avatar
Just curious, is there any advantage to bypassing the throttle body in warm climates? Would doing so bring down temps or raise them?
Old Aug 3, 2015 | 12:28 PM
ZGPhoto's Avatar
If anything it would increase heat, but the advantage would be reducing possible leaks.
Old Aug 3, 2015 | 03:15 PM
94svt50's Avatar
I would probably fix it. Nashville routinely gets below freezing from time to time in the winter. Somebody has bypassed it because was leaking. You need this to fix the leak Throttle Body Heater Plate Kit (Genuine Part # MGM000010) | Land Rover And Range Rover Fuel System Parts then re connect the hoses
Old Aug 4, 2015 | 06:58 AM
Where does the original hose come from and to exactly?
Old Aug 4, 2015 | 07:03 AM
drowssap's Avatar
from your recovery tank
Old Aug 4, 2015 | 09:18 AM
Alex_M's Avatar
I'm in the middle of the Blue Ridge Mountains in VA and I have mine bypassed. I drove it below -15 last year and it never froze a lick. I'd say don't worry too much about it.
Old Aug 4, 2015 | 04:54 PM
94svt50's Avatar
If it freezes it usually leaves the throttle plate in the open position. Kind of fun trying to stop that with those land rover stellar brakes. Its kind of like wearing a seat belt, might really never actually be necessary, just takes one time..
