Wheel Bearings
Dear Diary,
I slathered the centering ball w/ grease workes it in well. Re-installed went for 35 minute drive. Not a single noise.
Now, the million dollar question; replace or not to replace.
Over the weekend I was stuck in a pond. Is it pissible while trying to get out of the pond I "spun" or washed out all the grease from the centering ball. I say, yes.
I'm I gambling if I don't replace the shaft??
Yes your ""gambling "" its more likely that you got some grits of rock or sand around the centering ball or mixed in with the grease. At any rate i would replace it with aftermarket not a rebuild, but its your tranny when it seizes up.
And its in no way a million dollar question just a few grand vs a few hundred for a new prop shaft.
I'm having him send me one of his Reman shafts w/ greaseable everytihgn, including centering ball. The only one to offer this feature. In the meantime, he said my current shaft should be fine. It's bad U-joints that cause catastrophic failure to your rig, not so much bad centering ball kits.
