Originally Posted by unstable
(Post 66007)
-Drain the transmission.
-Break loose the fill plug and keep track of both plugs Good write up I need to do this. I usually loosen the fill plug first as a rule for Tranny and Diffs. Just in case. I know you are taking the pan off but I still like to loosen the plug first. Mainly because I am paranoid about not getting all the bolts out etc. |
Here is a great Youtube video on changing the transmission oil and filter:
Originally Posted by polar
(Post 65859)
I used the Valvoline pump.Part# VV818 $8.00 at the local parts store will fit into any Quart bottle I have seen.
Put the vehicle into park,start the vehicle,engage the EM brake,crawl under the vehicle while running in park and the EM on.Remove the upper most plug on the tranny pan,prepare the plug for reinsertition,meaning clean dirt/grit and repalce crush washer if needed,take the VV818 insert it into your favorite Trans fluid quart bottle. pump fluid till a slitedribble occures.remove pump tube, enter cab of vehicle and depress brake peddel.slide shifter leaver from park to First gear,leaving it 10 seconds at each notch/gear.once in first gear repeat steps backwards to park again. leave in park(vehicle still runing. crawl back under the vehicle and pump fluid till a steady stream of fluid comes from fill hole. reinsert the cleaned plug. wipe any fluid from pan(using caution and keeping clear of hot exposed parts) re enter cab and turn engine off. clean up items used.re enter cab and procede on test drive. Task Complete. |
