Where is my Diagnostics Port?
Old Apr 3, 2007 | 05:52 AM
The Didge's Avatar
5th Gear
Default Where is my Diagnostics Port?
Hi,
ive looked hi and low, on all diffrent kinds of manuals and cant find my diagnostics port...
can anyone point me in the right direction before i rip all the interior out
thanks
Old Apr 3, 2007 | 11:13 AM
robdis96's Avatar
Default RE: Where is my Diagnostics Port?
OBDII port?? YR/model?? DI/DII Should be right under the steering wheel at the bottom of the panel. Follow the panel where the steering wheel meets the the dash/instr panel to the bottom and it should be there.
Hope that helps.
Old Apr 3, 2007 | 11:17 AM
The Didge's Avatar
5th Gear
its a 94 3.9v8, does that help? ill have a look in a lil bit, thanks for ur help
Old Apr 3, 2007 | 11:33 AM
robdis96's Avatar
give it a shot, let me know
Later
Old Apr 3, 2007 | 11:38 AM
You have an OBD1 with no port but you do have an led display under the passanger seat.
If you need more information on reading it and the codes, shout.
Mike
rishi
Aug 17, 2012 12:19 PM
OFFROVIN
Mar 27, 2010 12:25 PM
Charles King
ROAMING WITH FRIENDS
Mar 27, 2008 03:25 AM
Charles King
Mar 27, 2008 03:23 AM
Roverscout
Mar 26, 2006 06:47 PM
