why oh why???
Old Dec 18, 2008 | 03:47 PM
rcpeddie's Avatar
7th Gear
Default why oh why???
I am a ``leak freak``... I am seeing orange coolant drips coming out of the little square hole at the base of the housing that bolts to the engine. I think the torque converter lives in this bell housing?? (Usually where the clutch lives on a stick model).Why is coolant coming out the transmission???????[:@][:@][:@]
Old Dec 18, 2008 | 03:57 PM
ryanD2's Avatar
Default RE: why oh why???
do you park on a grade? like nose of truck is higher than rear?
Old Dec 18, 2008 | 04:02 PM
rcpeddie's Avatar
7th Gear
yes...a little grade...the driveway
Old Dec 18, 2008 | 04:09 PM
ryanD2's Avatar
more than likely a leak on the engine that finds its way to the lowest point. swipe your hand under the throttle body and see if its wet. mine leaked on the drivers side valve cover and found it way to the same point when i parked with the front end higher than the rear.
Old Dec 18, 2008 | 04:14 PM
rcpeddie's Avatar
7th Gear
all is dry and good all around inside the whole engine bay, even underneath all is dry except at that little hole on the housing...uts coming out there....[:@]
Old Dec 18, 2008 | 04:28 PM
ryanD2's Avatar
i hate to jump to conclusions but if there is a leak in the trans cooler and the truck is shut off, the pressure still builds in the coolant system and can find its way into the trans through the cooler, check to see if the expansion tank holds pressure after the truck had been hot and sitswhen turned off. i have aslo heard of the casting hole leaking, core plug on the back of the block, not common but i suppose it could happen. But first and foremost i would make sure nothing is leaking in the engine bay, heater core hoses, any coolant lines anything that has orange fluid.
Old Dec 18, 2008 | 04:31 PM
Lets don't worry about the angle at which you park, it won't be causing the leak. Certainly check to make sure the t/body heater is not leaking but odds are it will be the valley pan gasket or the headgaskets. Either way, geep filling your coolant bottle to the very top every morning when the engine is cold, drive the truck little as possible and get it into the shop.
Let us know what they find wrong and the estimate for the repairs, some shops charge way to much for repairs.
TRIARII
Off Topic
18
Jan 27, 2014 12:06 PM
Landdaddy
Jun 13, 2006 11:27 PM
05LandRover
Off Topic
May 19, 2005 11:55 PM
Trader4Less
Jan 22, 2005 08:05 AM
