Will this bumper fit??
1 Attachment(s)
I found this truck at a local junk yard and it's a 2000 Discovery and I have a 2004 Discovery.. It's ARB bumper and its going cheap!
I can weld and make modifications if I need to... Your thoughts?? |
It will bolt on to your 04 with no modifications to the frame or bumper. No welding required. 00 and 04 have same frame.
1 Attachment(s)
I've heard that, but even the ARB website is indicating differently...
ITs a difference in the plastic grill which will not cause you issues. It will bolt right on no problem.
Cool thanks guys
1 Attachment(s)
I have an 00 with the 04 ARB bumper. It will fit but there will be a slight gap at the grill because the 00 grill dips down a little. You won't even notice it, especially behind the lights. Be sure to get the frame extensions/crush cans.
Only difference between the two is the grill space and the fog lights. Plus you'll have those pusher bumps on the front face and I don't :( And you might have a recovery point. The 04 also has a spot for the round fogs. Attachment 35263 |
