winch help/opinion's
#21
I didn't know you had a Maasdam. I'd have suggested just using that for now and create a winch fund until you can get a good winch. I've read a few good reviews of the HF one, and a lot of bad reviews.
A winch should be considered a safety item, not just a recovery tool, and I'm not at all a fan of cheaping out on them.
But if you do go forward with it, always keep your Maasdam with you. You're likely going to need it sooner than later.
FWIW, those 20% off coupons don't typically apply to sale items. Read the fine print.
#25
From what i have found out , the harbor freight winches are not sealed so you gotta waterproof it before you put it on the truck just because you cant get to it between the frame rails ...Buddy of mine had one and it worked great before it got wet , then when he needed it it would not work ...He tore it apart and cleaned everything , sealed it up and it works great...
I am going with a smittybuilt winch once i get my bumpers and figure out what will fit in the tray. I am going with the biggest that will fit in the space and going with there Smittybilt Part 98210 - XRC10 Comp Series 10,000 lb. Winch -RH1
#26
i have the older 10k or 12k harbor freight winch removable mounted on my trailer and have hauled a 1946 ****** cj2a with plow and lock up brakes from a guys yard onto my trailer, my broke down backhoe onto the trailer and ww2 6x6 with locked up trans up a steep concrete driveway and onto the trailer, it is slow but does the job, the newer ones have a better looking free spool lever, I also have mine setup to mount to the front or rear hitches on my dually
it has sat outside uncovered in all weather on the trailer for 7 +years with no problems I have never submerged it though
if I needed another winch, for the money I would buy another hf one mine has never not worked just the old style spool release isn't the best
#27
so I bought the HF 12000 lb winch today, Tom they did give me the 20% off so I paid 319.99 for it out the door. I will water proof it but for 3 bills you cant beat the price. I will update on the performance of it. I read a lot of good reviews. Tom I will take the Maasdam with me, thanks everyone for all the amazing help and advice.
#28
If you check the specs on these winches, you'll see that the HF ones are lower hp motors that make up for the power by using lower gearing which makes for a slow winch. Most cheap winches uses the same motor for all sizes and just change gear ratios. Check the ratios and line speeds. A lower power winch with a ****** block and used with the cable down to one layer on the drum will pull drum twice it's rating. I have a Smittybilt XRC8 which I have had good luck with and heard good things about. It is made in China like all cheap winches, Superwinch and low end Warn included, but seems to have some of the better specs. I looked for a used Warn but found nothing.If I was using this truck as a serious wheeling rig I would have gone with a much better winch but this one works great for me. I imagine it will need to be taken apart and cleaned up every few years but for $279 delivered I'm ok with that.
#29
If you post how long the cables are from the solenoids to your battery, and what the current draw of the winch is, I'll let you know what size cables you need. I bet you dollars to doughnuts they aren't large enough for optimal performance and motor life. Few stock cables seem to be.
#30
