Window issue, failed inspection
Old 08-14-2015, 10:24 AM
drowssap's Avatar
are you sure your truck failed because of the window? I find that hard to believe.
And exactly what station was it that failed the truck for a window not working?
Ma. does not even recognize hand signal anymore, which is the only possible reason BS reason I could think. and that would only be if your directional did not work to begin with. window tint is the only question on the safety inspection not operation
Attached Thumbnails Window issue, failed inspection-img_20150814_112801750.jpg
Old 08-14-2015, 10:47 AM
drowssap's Avatar
it should be hard to get it straightened out, i remember a guy that would not give me a sticker because he said could not see the front plate because of the plow frame.
I called the registry and talk to one of the inspector, he told me to go back. When i got there the guy very pissed off put the sticker on.
Old 08-14-2015, 01:17 PM
Charlie_V's Avatar
Hahah that's a great story!
Mine failed one time. There was a drop of brake fluid on the ABS controller. I got this little lecture about how dangerous it is and that it could cost 2000 dollars to fix and blah blah. I've NEVER failed an inspection in my 48 years. I backed out of the bay. Tightened the nut. Wiped it off. Pulled right back in. He slapped the sticker on it.
Later that same day a pickup was tailgating me on the highway. CLOSE. I got out of the way and he blew out the rest of his engine passing me. His hood was bobbing up and down with baling wire holding it his windshield was cracked. And one headlight and one taillight were literally bolted and taped over their unfortunate predecessors and clearly from some other vehicle. And yep, you guessed it, he had a brand new inspection sticker (first day of the month).
Old 08-14-2015, 03:18 PM
weepit's Avatar
Well I failed for 3 things but 2 I can fix easy. I have a brake light out in the rear and he said my tires were bald. He then said he could fix for me but I said no thanks. Figure I can get tires cheaper at a big store and I can do the bulb. Door was the tricky one.
It was a Shell station in my town, I've gone there before and passed fine. Just not my year!
Old 08-14-2015, 04:44 PM
drowssap's Avatar
It failed for the tires and brake light not the window. As you can see by the report i posted window tint is the only inspection requirement
Old 08-14-2015, 05:04 PM
weepit's Avatar
Well he said the window For certain. Hmm. I have the report in my truck, will check later. Not disagreeing with you, just repeating what he told me.
Edit: just checked, there are 3 fails. For the window he failed me on a category called "other", so it doesn't say window, but that is what he told me failed. Glad I checked, thanks for the heads up
Old 08-16-2015, 10:25 AM
Charlie_V's Avatar
Well whatever the failures the windows has to be fixed. I found the washers I mentioned and put them on this morning... uncertain success.
Short video:
Uploading... I'll add it in a few.
Okay I'm an idiot and a I have a BLACKBERRY so there is no video.
EDIT: blackberry redeemed. Here's the
The upshot is that the rollers are non replaceable. The partial solution is the get the washers pictured above, heat them, them press two washers over the stud. The reason this is a partial fix is that the original roller is about as thick as the two washers (1/8 inch) but has a collar on the back that is part of the roller. The collar keeps the stud tight and spaces the arm away from the track. Without the collar, the washers do roll in the track but the stud is able to move around and the arm will not space away from the track.
When I completed this repair it immediately stuck. I while "videoing" I didn't stick and for the next twenty times it didn't stick.
IMHO the only way the washers would work is to place something else behind them to mimic the collar.
Anyway, it seems to work. I'm not happy. A member was selling a fix some time ago but I can't find it. I have four doors from a parts truck and, of course, the rollers are all fine except that on the driver's side.
If anyone knows where the member fix (part) is I'd sure appreciate a link.
weepit (08-16-2015)
Old 08-16-2015, 11:55 AM
Some, not all, of those Mass regs are a bit onerous acamato .......................... problem is I have found here if you challenge the CT people they'll nail you on something else ................. here they can be quite spiteful.
Old 08-16-2015, 05:33 PM
weepit's Avatar
Thanks Charlie, awesome help. Maybe I could get one at a junkyard or from one of parts guys? Might have to buy the whole door...
I'll try searching here too but I've never had great success with search function here, it finds too much.
Old 08-16-2015, 05:45 PM
weepit's Avatar
Quick Reply: Window issue, failed inspection
