Window regulator motor...'03 DII
Old Jul 14, 2008 | 09:17 AM
pelias's Avatar
4wd High
Default Window regulator motor...'03 DII
Ok...I thought I had a broken regulator...passenger front window rolled down then stuck and wouldn't go up. I took the panel off and found the white broken washer (roller) in the bottom of the door. Immediately ordered new regulator and started the installation. Once I took the old regulator out I realized it was perfect. The washer must have been from a previous replacement. Now I am thinking the motor. When I hit the window button it clicks, that's it. Guess I'll order the motor now. Question, is there a way to get the window up and keep it there until I install the motor?? Thanks!
Old Jul 14, 2008 | 09:24 AM
DiscoRui's Avatar
Default RE: Window regulator motor...'03 DII
Try to hard wire the window regulator it's easy
Old Jul 14, 2008 | 10:02 AM
http://www.roverlandparts.com/ is a great place to save money and buy a good guaranteed used motor.
Old Jul 14, 2008 | 10:08 AM
pelias's Avatar
4wd High
Thanks guys...gonna order the motor today.
RedAustinIX
Aug 10, 2020 11:43 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
darrenh1975
Aug 5, 2007 03:41 PM
zachbraff
Jul 18, 2005 12:57 AM
