Window Regulator troubles
I am having trouble with the window regulator, the half gear that moves the window tracking has fallen off, is this replaceable? the motor on the window still works fine, i am not sure how to re attach this or if i have to buy a new one, any help would be greatly appreciated.
Thanks guys! |
Originally Posted by Amazze
(Post 459907)
Thanks guys! Sh!t video but you can see the three spot weld that hold the semi circular winder rack on. If possible drill these out and replace them with peened rivets or even hard pop rivets or possibly spot weld them again. I'm not sure whether you have enough room to be able to screw/bolt them together. New regulators are very cheap on Ebay in any case. Take note of the video as this will also happen in time as it's happened to mine, basically the motor drive overruns the rack and drops off the end. |
Save yourself the headache and get a new or used one. Which window is it for?
thanks, it almost seemed silly to ask, i saw the rivets that were once holding it on, but it was such a cheap way to hold it in place i almost couldn't believe it, so i figured i would ask.
I have all window regulators in stock. You can reuse your same working motor, just attach it to a new regulator. They're cheaper than you might think.
Shoot me an email or call if interested. |
Originally Posted by ralphobell
(Post 459957)
(Post 460057)
its the driver side door, I guess if i am going to replace it i may as well buy a new one. no sense in buying used if it could happen to the used part.
$40/shipped |
(Post 460057)
Mine did the same thing about 2 weeks ago and went with a new one. I have the door panel off when I had to manually raise it but still havent found the time to put the new one in. I have a walkthrough I found saved as a favorite on my PC and it looks pretty simple or at least compared to the lock actuator I had to replace a year or so
back Here is the post I was going to use for assistance https://landroverforums.com/forum/di...-repair-34345/ |
Originally Posted by jdwilks
(Post 460116)
Mine did the same thing about 2 weeks ago and went with a new one. I have the door panel off when I had to manually raise it but still havent found the time to put the new one in. I have a walkthrough I found saved as a favorite on my PC and it looks pretty simple or at least compared to the lock actuator I had to replace a year or so back
