Window Switch modification
The other day I created my first useful modification to my D2 (which would work in a D1 as well). I was reading about the CDL installation, and one of the instructions was to remove the console panel with the window switches.
It seems that any time I have a passenger in my car, and they want to roll down the windows, they choose the wrong window - rolling down the back instead of the front. This has bothered me too (as a UI designer) - even though the switch position "maps" to the car (bottom switches = front, top switches = rear) instinct has us click the closest switch first. In any case: -remove the cover from the switch panel (it just pops off) -remove the switch panel (4 phillips screws, don't drop them down the hole) -Unplug the top and bottom switch wires on one side; they're different colors and have a latch on the side. -Remove the two switches themselves - they have latches top and bottom. (I assume they're different, maybe this step isn't even necessary) -Reverse the switches. -Reverse the wires. -Repeat on the other side -put it all back together. -Windows now work as they "should". I did this while waiting in line at McDonalds, with a multitool in one hand and an XL Diet Coke in the other. |
| All times are GMT -5. The time now is 11:48 PM. |
