Wiper Switch Fix
Old Dec 5, 2012 | 02:06 PM
  #21
BTamas's Avatar
4th Gear
I'm very happy whit this write up too. Mine started not to work yesterday, and it took only an hour to repair it (after I read the instructions and photos). And I did it on the other side too with the headlight arm/lever, for prevention. It was the same method.
Thanks a lot
Old Jan 12, 2013 | 10:46 AM
  #22
mikesdisco's Avatar
about to attempt this wish me luck
Old Jan 12, 2013 | 03:43 PM
  #23
CANAMDiscovery's Avatar
No luck required... but hopefully it works for you.
patience and a little time.
Old Jan 23, 2013 | 09:16 AM
  #24
collector87's Avatar
Awesome! I'll try this - thanks!
Old Apr 6, 2013 | 12:15 PM
  #25
kgrab's Avatar
Thanks for the post, worked for me as well. I think this would be a good addition to the write up's sticky?
Old Apr 6, 2013 | 01:05 PM
  #26
dr. mordo's Avatar
Agreed!
Nice work. This is why I love Land Rover owners. With my volvo it's like I'm the only DIYer out there.
Old Apr 7, 2013 | 07:38 AM
  #27
RANDY04D2's Avatar
Default Great wrtie up...
Yea, mine are intermittent too. Gotta flip the stalk numerous time to get em wiping. Will get to it soon, printing your fix now, fantastic,thanks....
Old Apr 7, 2013 | 08:32 AM
  #28
RANDY04D2's Avatar
Default Wiper switch alternate.....
Tried the fix, I was unable to get the switch out of housing after removing screws. Was afraid to break something with flat screwdriver as was putting on much pressure. Was able to get contact cleaner with straw attachment all around where stalk goes into switch. Move stalk around while spraying with straw. I pressed in on stalk hard and moved in all directions as to make better contact with contacts and clean them better. Not as good as proper fix but im not waiting around for new switch to come in mail...... 3 phillips screws on bottom of coloum plastic housing. Drop fuse panel door to get at third screw. Then the lower housing has 4 plastic tabs that click into upper housing,so push in on the upper casing at parting line to unlatch plastic tabs and seperate coloum plastic......hope this helps if unable to release switch...
Old Apr 8, 2013 | 01:50 AM
  #29
Randy..
It does require a pretty firm pull on the wiper switch... Was a little scary the first time I yanked on it!!! Swore a screw was holding it that I could not see.
I did my light switch column too, it released from its bracket much easier than the wiper.
You probably loosen up some of the old grease and are getting good enough contact now. If it gums up again, you know how get at it.
Old Apr 14, 2013 | 12:32 PM
  #30
dilbertland's Avatar
Default Another one fixed
Thanks CANAM, another successful repair to report. So easy, wish I had done it sooner. The caked grease was even worse than your pictures.
