Wires pulled out of plug!
Old Aug 30, 2008 | 09:25 PM
toddbelt's Avatar
4wd High
Default Wires pulled out of plug!
Greetings all, my first post and of course, it's out of desperation!
After dismantling my 98 Discovery passenger side interior and successfully clearing a blocked AC Condensation Line (thanks to this forum!) I was almost completely reassembled when I push a bit too hard on reinstalling the panel on the passenger side. Five colored wires pulled out of their plug (this plug is actually bolted to the car) and immediately, the horn started blowing. Now, the window controls don't work.
My problem is, I don't know what the color sequence is to reinsert the five wires into the plastic plug.
What do I do? I've looked all over the Web for the past 7 hours and can't find a specific wiring diagram to tell me what the sequence is for these wires. Can anyone give me advice?
Thanks tons in advance.
Old Aug 30, 2008 | 09:32 PM
Default RE: Wires pulled out of plug!
Can you post a pic of it? Maybe somebody knows what you are talking about if they see a pic.
Old Aug 30, 2008 | 09:47 PM
toddbelt's Avatar
4wd High
Will do Spike, first AM. Sorry that I didn't post with a pic to begin with.
Thanks for the speedy reply.
Todd
Old Aug 30, 2008 | 09:50 PM
No problem, this sounds complicated so a visual referance will get you better results.
Old Aug 31, 2008 | 10:56 AM
toddbelt's Avatar
4wd High
Sorry for not posting Pics sooner - thanks for the nudge Spike!
The first pic is for a reference zone - I'm working in the Passenger floor fuse area
The second Pic is of the five wires that need to be re-seated in the plug.
The third Pic is of the empty plug in it's original mounting location, in need of some wires!
Help!!! (and an eternity of thanks!)
Todd
[IMG]local://upfiles/11315/E3AC9ADE49D3415EAE07632B1EFD10D1.jpg[/IMG]
[IMG]local://upfiles/11315/A6AD9B97CE2843CA8C5D7B9DE1FF3752.jpg[/IMG]
[IMG]local://upfiles/11315/3991CE488C034840840913FF20045F0D.jpg[/IMG]
Old Aug 31, 2008 | 01:59 PM
Disco2Guy's Avatar
Aren't there rubber nipples for the a/c drains under the truck? Maybe it's different on a D1, but I've never heard of removing all those panels to clear the drains
Old Aug 31, 2008 | 02:47 PM
toddbelt's Avatar
4wd High
Greetings Disco2Guy,
Nice catch! The reason for my disassembled passenger area was because I was attempting to squeeze out the gallons of accumulated water that was collected in the underlayment under the carpet. I figured it would be easier to roll back the carpet, which was pinned down by the Right-Side kick plate, which also covers up the fuse/electrical area. I was able to get much of the water extracted, the AC Condensation rubber nipple cleared out, and everything back in place except for the last kick-panel before I caused my problem.
Fix one thing, cause another...
If I had access to another Disco I, I could go look at the color sequence of the wires and fix this problem. Unfortunately, it won't start due to the Theft Prevention System/Alarm (and I assume something to do with five electrical wires not being connected!) and it's a holiday weekend, so no help from my LandRover Service Department until Tuesday...
And then, desperation sets in...
Old Aug 31, 2008 | 03:01 PM
Can you match the wires to the same color wires on the otherside of the connector?
Our camera died last week and we cannot find the old one, once we do I will try taking a pick and posting it for you.
Old Aug 31, 2008 | 03:35 PM
Ok, took some pics, once my wife uo-loads them to her computer and then e-mails them to me and I up-load them to Photobucket I will post them on here.
Not sure if I got the correct plug or not though.
Old Aug 31, 2008 | 03:44 PM
Disco2Guy's Avatar
Ok, that makes sense. I use a small boat fan I can shove under the carpet to help dry it out. That foam really can hold a lot of water huh?
