Yet another engine cooling question
So my Disco 2 runs around 204 to 208 while driving but will run to 212 to 215 at idle . I can put it in neutral and rev the engine to 1200 rpm or so and the temp quickly drops back to 206 or so. Ive checked the
bleed several times in the morning and no air appears to be in the system. The radiator is fairly new as well. Im thinking water pump impeller may be about shot. Any thoughts? 75k on the original WP.
I glad you posted this. My disco does the exact same thing and I am always paranoid something is wrong. I’ bought a new fan clutch and tried to install it but I could not for the life of me get the clutch off. It’s a project I have to tackle later on but I think my clutch spins a little too freely.
Thanks guys, the aux fan is coming on at 212. Im running the stock tstat right now . I have a 180 tstat to install. Ill install that and see what happens. I also see no side plates between the ac condenser and the radiator....shouldnt there be one on each side to direct the air into the radiator better?
