Camera System Fault
Hello Disco Owners,
Have a 2016 Discovery Sport with 5K miles so far and keep getting the annoying Camera System Fault intermittently! It used to happen only when I would start the car. Initially I didn't bother much as restarting the car would fix it. But now it is happening while driving and I keep getting the warning in the instrument cluster. Pressing OK just clears the warning and restarting isn't fixing it anymore. But again it is intermittent, doesn't happen always. Has anyone else experienced the same ? Called in for an appointment with the dealer tomorrow, will update the outcome. https://cimg4.ibsrv.net/gimg/landrov...66b5902a40.jpg https://cimg3.ibsrv.net/gimg/landrov...f6f2ecbdd9.jpg |
What was the resolution? Having the same issue with mine.
The dealership tried to reset the camera system and flush out any codes in the vehicles, but the issue kept coming back. Finally they replaced the camera which resolved the issue. Had to get the vehicle in a couple of times to get it sorted out. Since my vehicle was still under warranty, all of it was free.
Good luck with getting yours fixed. |
Brandon, I am also having the same issue (2016 RR) with the camera error. Was yours resolved by replacing the camera(s) as well?
TKP: How many cameras replaced? If one, location? |
BTW, I am also getting "Limited SOS Functionality" error msg. Any ideas for resolution?
I have the Solution about this FAULT
EASY SOLUTION [ Camera system failure ] JAGUAR XE XF ⚠️ Solution to the FAILURE in the camera system in Jaguar cars ⚠️ ✅ The issue of cameras is easily corrected ✅ In this case it is in an XE perl the solution is easily extended to any vehicle XJ XK F pace E pace F type etc ➡️ Tell us if you ever had that problem and how you solved it 👍🏻 Give it a like 👍🏻👍🏻👍🏻 jaguar xe camera #jaguar #xe #xf ☝🏻 subtitles if you don't know spanish friends
The above poster is posting same thing on several forums,,,spammer?
