Problems with my RR 1999: 4.0L
I am new in this forum and I really need help with my car, I am driving Range Rover 1999 – 4.0 L and below is my serious problem with my car and I would like to fix them… I love this car even though is very old:
1.)Back wiper works but, the nozzle WON’T SPRAY WATER. 2.)Key problems: won’t open the doors from far also, trigger alarm and LOCKED THE ENGINE. I put in the car starter, wouldn’t work car won’t stop (I took it out). 3.)Dash board lights are dead… ONLY THE ODOMETER (YOU CAN NOT SEE THE NUMBERS/MILES) 4.)Water problems: water gets in the car sides all the way down in the floor… I changed the sunroof the whole panel and cleaned the 4 drains AFTER CAR WASH AND HEAVY RAIN WATER ON THE FLOORS: ONLY FRONT DRIVER’S AND PASSENGER. 5.) Any opinion on leather repair? Thank you all for your help. Joseph. RR 1999 - 4.0 L. |
Any luck with this list? Let me know
You're not likely to get any responses in this section. Its description: "This section is NOT for vehicle technical questions. This section is for problems or suggestions for the forum itself."
no luck... any help?
Originally Posted by BritishautoworksSD
(Post 561459)
Go back to the forum home page and post your questions in the Range Rover forum: Range Rover - Land Rover Forums - Land Rover Enthusiast Forum
2.) This sounds like a driver's door latch is not working correctly or the engine control unit has lost synchronization with the immobilization control unit. Do you know if the engine management is a Bosch or GEMS? Most likely the door latch is the problem especially if the remote is not working correctly. |
That make sense, I did replaced the door latch... the engine is Bosch... was I supposed to do something else (any details will be great) thank you.
