Freelander Talk about the Land Rover Freelander within.
Not Starting
Old Feb 16, 2009 | 10:39 AM
Rayyag's Avatar
Default Not Starting
Hi, I have a 2003 land rover freelander and when I go to start my car it takes about 20-30 mins to get the car started. I put the key in the ignition and when I turn to start it, it will not catch, the lights, radio and heat turn on but it doesn't start, so after 10-30 minutes of turning the key it will finnaly start, does anyone know what the problem could be?
Old Feb 16, 2009 | 06:48 PM
roverguy7's Avatar
does it crank and not kick over, or does it not crank at all.
Old Feb 21, 2009 | 06:54 AM
TurkeyVegas's Avatar
Same thing with me turn key nothing, no crank or turn over but then on the 12 -25 try it will start to crank over then start? this is not random but every time I try to start it??
any idea where I should look?
Old Feb 22, 2009 | 03:58 PM
roverguy7's Avatar
they occasionally have problems with the immobization system, two parts of it. both the inductor ring that reads the id of the key, and also the immobilization ecu itself, it needs to be checked out by someone that has a testbook computer so they can see the inputs... or it could be something as easy as the starter relay.
Old Mar 18, 2009 | 02:50 PM
Rayyag's Avatar
Hey Roverguy7, the rover just starts after awhile no hesitation just starts after awhile, Since my post I thought it was the starter,I brought a new one and come to find out my old starter tested good, so it was not the starter, now I don't have the slightest idea as to what it could be?
Old Apr 19, 2009 | 12:05 PM
Rayyag's Avatar
Hey thanks everyone, the problem was the ignition switch, I brought a new one and installed it, and no more problems with starting my rover!
Old Apr 25, 2009 | 09:31 AM
Butters1's Avatar
Hi Rayyag, I also have an 03 Freelander with a seemingly similar problem.... it will crank over.... but not fire..... only happens every now and then (usually when my wife is shopping).... I had LR dealership look over it but car was starting fine on the day so they left it.... of course that evening it wouldn't start.... i normally leave it for half an hour... come back and it starts fine...... can i ask how you found that was ignition switch...??
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
readdiscovery
Jul 7, 2006 05:23 PM
nick
Freelander
Mar 14, 2006 04:41 PM
pants
Oct 19, 2005 12:47 AM
nick
Jul 17, 2005 02:04 PM
