1993 won't start
I recently bought a 1993 RR LWB 4.2ltr. It won't start. I put a new fuel pump in, pulled the distributor found TDC and place it back in so the rotor was facing the #1 piston which is the 1st one on the drivers side "I hope" and put the plug wired in the correct order "I hope". It seems to be getting fuel and spark it just won't start. I fixed the arching problem to and also replace the the coil. Any ideas? Thanks
EFI computer along with the coil pack went out in my boss's. If you are sure the coil pack is good, and the fuel pump is good. Then its either the crank shaft position sensor (don't know if the classics had them) or the EFI computer or fuse. To check the firing order, see the RAVE service manual.
