1993 won't start
Old Jan 14, 2010 | 03:16 PM
elkhutr's Avatar
5th Gear
Default 1993 won't start
I recently bought a 1993 RR LWB 4.2ltr. It won't start. I put a new fuel pump in, pulled the distributor found TDC and place it back in so the rotor was facing the #1 piston which is the 1st one on the drivers side "I hope" and put the plug wired in the correct order "I hope". It seems to be getting fuel and spark it just won't start. I fixed the arching problem to and also replace the the coil. Any ideas? Thanks
Old Jan 14, 2010 | 06:51 PM
LRScott's Avatar
EFI computer along with the coil pack went out in my boss's. If you are sure the coil pack is good, and the fuel pump is good. Then its either the crank shaft position sensor (don't know if the classics had them) or the EFI computer or fuse. To check the firing order, see the RAVE service manual.
Disco Alan
Nov 21, 2014 09:21 AM
toad2
Jan 17, 2014 09:19 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
