2003 RR HSE...what to look for.
This one is at my local Nissan dealer. I'm thinking about upgrading my wife's car and this looks nice (obviously way over-priced).
Kalispell, MT 2003 Land Rover Range Rover HSE Used SUV spokane,wa Missoula, MT Green Nissan I looked for a 'sticky' but didn't see any in this section of the forum. From what I've read, the ride-height control and trans are two of the major issues. How can I check those out? Being a Nissan dealer they likely don't have service records. Thanks! :) |
I would look for the 2005 version it has a touch screen and it also should have most of the bugs worked out. The truck your looking at can be found for about 15K.
Look in Los Angeles on Craigslist for better deals |
If it breaks, how far to nearest dealer from Whitefish? Complexity of systems is quite a bump from your repaired Disco.
Long ways Savannah and yeah, a big jump!
I went by the stealership and drove it today. It seems like everything works. Drives really well and has a lot of geddy-up! I can't tell if the air-suspension was working or not. It seemed to sit rather high. I tried lowering it and the light illuminated for the low position but a few miles later is back in the center. Normal? I'd like to know where the compressor is so I could hear it run. They showed me receipts for about a $1400 in repair work done at the dealer. Of course that included normal lube/oil-change and detail, etc. The only real repairs done were replacing two O2 sensors and valve cover gaskets. They also replaced a CV boot. I asked to see any previous service records and they said they were all purged due to privacy issues. If we had a dealer nearby I could probably check with them but I have no idea where it was getting serviced. It is a local trade though. The biggest disappointment I had with it was all the plastic bits on the interior were peeling color away. It sure felt like a rocketship after driving the D1 down there! I told them we should trade seeing as they are the same color and all. I'm waiting for the CarFax now but they have already said they won't come down on the price more than about $500. I was also thinking $15K. Trade-in is only $14K so you know that's probably all they gave (if that). |
Your AutoCheck Vehicle History Report
2003 Land Rover Range Rover Report Run Date: 2012-02-14 19:15:40.179 EST Report Summary
This vehicle's AutoCheck Score https://www.autocheck.com/members/re...oreTile_01.jpghttps://www.autocheck.com/members/re...oreTile_02.jpghttps://www.autocheck.com/members/re.../images/S7.jpghttps://www.autocheck.com/members/re...oreTile_04.jpghttps://www.autocheck.com/members/re.../images/S9.jpghttps://www.autocheck.com/members/re...oreTile_06.jpghttps://www.autocheck.com/members/re...oreTile_07.jpghttps://www.autocheck.com/members/re.../images/R5.jpghttps://www.autocheck.com/members/re.../images/R9.jpghttps://www.autocheck.com/members/re...oreTile_10.jpghttps://www.autocheck.com/members/re.../images/R8.jpghttps://www.autocheck.com/members/re.../images/R2.jpghttps://www.autocheck.com/members/re...oreTile_13.jpg The AutoCheck Score is a summary of your vehicle's history. It lets you compare similar vehicles with ease. About the AutoCheck Score This vehicle qualifies for Buyback Protection Safeguard your investment with AutoCheck Buyback Protection. It reduces the risk in buying a used vehicle. About Buyback Protection AccidentCheck Reported accidents: 0Title and ProblemCheck Your vehicle checks out!OdometerCheck Your vehicle checks out! Last Reported Odometer Reading: 57,090 Vehicle Use and EventCheck Specific vehicle use(s) or events reported View Full History https://www.autocheck.com/members/re...de_details.jpgAccidentCheck Not all accidents / issues are reported to AutoCheck. https://www.autocheck.com/members/re...-accidents.jpg Your Vehicle Checks Out! There have been no accidents reported to AutoCheck for this 2003 Land Rover Range Rover (SALME11473A128317). AutoCheck receives its accident data from government sources and independent agencies, and based on the information available to us, we have found that no accidents have been reported on this vehicle. https://www.autocheck.com/members/re...de_details.jpgTitle and ProblemCheck Your Vehicle Checks Out! AutoCheck's database for this 2003 Land Rover Range Rover (SALME11473A128317) shows no negative titles or other problems. When reported to AutoCheck, these events can indicate serious past damage or other significant problems, and disqualifies the vehicle for AutoCheck Buyback Protection. Check the Vehicle Use and EventCheck for reported accidents that can affect vehicle safety and value. 0 Problem(s) Reported:15 Title/Problem areas checked: No abandoned title record No damaged title or major damage incident record No fire damaged title record No grey market title record No hail damage title record No insurance loss title or probable total loss record No junk or scrapped title record No manufacturer buyback/lemon title record No odometer problem title record No rebuilt/rebuildable title record No salvage title or salvage auction record No water damaged title record No NHTSA crash test record No frame/unibody damage record No recycling facility record https://www.autocheck.com/members/re...de_details.jpgOdometerCheck Your Vehicle Checks Out! AutoCheck examined the reported odometer readings reported to AutoCheck for this 2003 Land Rover Range Rover (SALME11473A128317) and no indication of an odometer rollback or tampering was found. AutoCheck uses business rules to determine if reported odometer readings are significantly less than previously reported values. Not all reported odometer readings are used. Title and auction events also report odometer tampering or breakage. 0 Problem(s) Reported:MileageDate Reported834 01/22/2004 20,614 07/06/2005 22,752 10/13/2005 31,433 08/08/2006 50,967 09/12/2007 53,566 12/26/2007 57,090 04/28/2008 https://www.autocheck.com/members/re...de_details.jpgVehicle Use and EventCheck Information Reported! AutoCheck shows additional vehicle uses or events reported to AutoCheck for this 2003 Land Rover Range Rover (SALME11473A128317). This includes reported vehicle uses such as rental or lease, and events such as whether the vehicle has been reported to have had a loan/lien or a duplicate title issued. Other events show if the vehicle has a reported accident and how many calculated accidents or if it has been reported stolen or repossessed. It is recommended to have pre-owned vehicles inspected by a third party prior to purchase. 0 Event(s) Reported: 6 Vehicle uses checked: No fleet, rental and/or lease use record No taxi use record No police use record No government use record No livery use record No driver education record 2 Event(s) Reported: 9 Vehicle events checked: No accident record reported through accident data sources No corrected title record No duplicate title record Emission/safety inspection record(s) Loan/Lien record(s) No fire damage incident record No repossessed record No theft record No storm area registration/title record Full History Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text. Report Run Date 2012-02-14 19:15:40.179 EST Vehicle: 2003 Land Rover Range Rover (SALME11473A128317) Event dateLocationOdometer readingData SourceDetails01/22/2004 FL 834 Motor Vehicle Dept. ODOMETER READING FROM DMV 02/12/2004 NAPLES, FL Motor Vehicle Dept. TITLE (Title #:0089850895) (Lien Reported) 02/12/2004 NAPLES, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 09/21/2004 NAPLES, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 07/06/2005 DALLAS, TX 20,614 Independent Emission Source PASSED EMISSION INSPECTION 10/05/2005 DALLAS, TX Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 08/08/2006 HOUSTON, TX 31,433 State Agency PASSED EMISSION INSPECTION PASSED SAFETY INSPECTION 10/01/2006 DALLAS, TX Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 09/12/2007 RICHARDSON, TX 50,967 State Agency PASSED EMISSION INSPECTION PASSED SAFETY INSPECTION 10/01/2007 DALLAS, TX Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 04/08/2008 WHITEFISH, MT Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 04/28/2008 WHITEFISH, MT 57,090 Motor Vehicle Dept. TITLE (Title #:H021907) 04/01/2009 WHITEFISH, MT Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 04/18/2009 WHITEFISH, MT Motor Vehicle Dept. TITLE (Title #:H021907) 04/01/2010 WHITEFISH, MT Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 02/01/2011 KALISPELL, MT Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 02/11/2011 KALISPELL, MT Motor Vehicle Dept. TITLE (Title #:AA0737278) (Lien Reported) 02/22/2011 KALISPELL, MT Motor Vehicle Dept. TITLE (Title #:AA0737278) (Lien Reported) This Vehicle's Glossary Below are the specific definitions for events that appear in this vehicle's report. More information is available in the full AutoCheck glossary. TermSection LocationDefinitionLoan/Lien Vehicle Use and EventCheck A loan/lien is the legal right to take and hold or sell the vehicle of a debtor as security or payment for a debt. Normally, a vehicle will have a lien due to a loan or unpaid repair bill against the vehicle. Check with the seller to ensure that the lien has been satisfied. Emission/Safety Inspection Vehicle Use and EventCheck An approved emission testing station has inspected the vehicle to measure the amount of pollutants the vehicle emits into the environment. |
Do yourself a favor, find a reputable Land Rover mechanic in your area
Have him look over the entire vehicle, read and record all the DTC codes in all the systems. Clear the codes and drive the vehicle and use all the systems (eas, hdc, hi lo range etc). Bring it back in and record all the codes again. Get an estimate or an idea of all the repairs needed then decide how much you are willing to spend on it. The few hours labor is well worth it to protect your investment, and sanity.. ...And remember, a diagnostic check over does not guarantee you any immunity from future problems that may surface.. |
Vehicle went on 'sale' this weekend for $18,788 and apparently sold. I was on the way down to take another look and let the wife drive it. Probably better off. Thanks anyway! Matt
