91 RRC ABS Issue
Old 07-15-2016, 07:36 PM
Roflcopter's Avatar
Default 91 RRC ABS Issue
So the other day, my ABS pump stayed on constantly for about a minute. I unplugged the pump and made it home. I decided to slaps some new pads on and bleed the system step by step until step 10(? stating if it was on for more than 45 seconds check for a leaks).
The pump stayed on but No leaks were present. So I figured i'd ask some land rover guys. They said that my pressure switch could have gone bad. So i ordered one(The AC DELCO one, which is literally a repackaged ATE one) and slapped it on. The pump was still constantly running.
So, I figured I'd pull the pressure switch off and try to push the button (simulating hitting desired pressure, also trying the old switch). You could hear the switch click on and off. The pump kept running with no change. So, i'm down to the relay possibly being stuck. Someone had said to swap with the identical relay to the left of the abs pump relay. I did this and still no change. So either both Relays are bad or my new switch is ****. I doubt it is, as it was a sealed unit. But it can happen.
How should i proceed from here? I need the truck this weekend and i can't seem to find a relay to swap with to at least narrow what is causing this issue. Anyone in the Denver/Boulder Colorado area?
Old 07-15-2016, 10:14 PM
Roflcopter's Avatar
So I tested the relays and they work perfectly. Someone said there is a pressure switch in the abs block that can control the pump, as well....investigating that now....
Old 07-19-2016, 11:07 AM
I'm assuming that the ABS light goes out while driving. If not, the ABS Control Unit has stored a fault.
401Rover
04-05-2016 03:30 PM
WNYErikDiscoII
11-07-2013 09:32 AM
Lincoln Tarantino
05-02-2012 11:20 AM
Paul Grant
36
03-14-2012 07:59 PM
danRRC90
04-09-2007 03:48 AM
Quick Reply: 91 RRC ABS Issue
