99'HSE A/C woes
Pleased to introduce myself. Name is Ajan- I reside in desert southwest
New to the Rover HSE - a 99' but have a 63 ssllA and an 86' 90 200Tdi ( my favorite vehicle to date) So what i get from lady I bought from - the a/c can be tempermental. every so often it will not work- Anyone know anything about this I speak of - i did a search and nadda i used to have an 94 that the unit under passengers dash would freeze up in hot weather- that only happened once though She was talking of having the dash removed and something fixed - thought I would check first ANy clues? please and thanks peace: |
RE: 99'HSE A/C woes
hi there
i used to have a suburban and the ac had trouble . i remember a friend of mine telling me to take a hammer and tap the ac-box under the console at the passenger side. he said that dirt can seaze it. i don't know if that is your problem, but the fact that your ac comes on sometimes made me think of it (or a lose contact) ceedee |
RE: 99'HSE A/C woes
Thanks Ceedee:
I will check this out- when checking out a car for a client- I was amazed at how much dust under the hood their was- desert living Your ideas is sound and I will check this out Thanks peace: |
RE: 99'HSE A/C woes
did you have any luck with this?
i have the same problem with my 97 hse, the a/c only works intermittently--don't want to pour money into it unless i absolutely have to, seeing as though it works at times i don't think replacement of all the components as my shop suggested was necessary-- |
RE: 99'HSE A/C woes
i have looked up a potential culprit, a "3-way pressure switch failure".
has anyone else had this problem? |
RE: 99'HSE A/C woes
joeysrover:
thanks for the reply: Uppon more research I draw your attention to : http://www.rangerovers.net/repairdet...lendmotor.html this guy has put together a fine site on the HSE- hope this helps- i'll post more as soon as I get to the cure peace: |
