99'HSE A/C woes
Old May 19, 2005 | 12:25 AM
nomadix's Avatar
4th Gear
Default 99'HSE A/C woes
Pleased to introduce myself. Name is Ajan- I reside in desert southwest
New to the Rover HSE - a 99' but have a 63 ssllA and an 86' 90 200Tdi ( my favorite vehicle to date)
So what i get from lady I bought from - the a/c can be tempermental. every so often it will not work-
Anyone know anything about this I speak of - i did a search and nadda
i used to have an 94 that the unit under passengers dash would freeze up in hot weather- that only happened once though
She was talking of having the dash removed and something fixed - thought I would check first
ANy clues?
please and thanks
peace:
Old May 19, 2005 | 12:01 PM
ceedee's Avatar
8th Gear
Default RE: 99'HSE A/C woes
hi there
i used to have a suburban and the ac had trouble . i remember a friend of mine telling me to take a hammer and tap the ac-box under the console at the passenger side.
he said that dirt can seaze it. i don't know if that is your problem, but the fact that your ac comes on sometimes made me think of it (or a lose contact)
ceedee
Old May 19, 2005 | 03:02 PM
nomadix's Avatar
4th Gear
Thanks Ceedee:
I will check this out- when checking out a car for a client- I was amazed at how much dust under the hood their was- desert living
Your ideas is sound and I will check this out
Thanks
peace:
Old Jun 13, 2005 | 05:28 PM
joeysrover's Avatar
did you have any luck with this?
i have the same problem with my 97 hse, the a/c only works intermittently--don't want to pour money into it unless i absolutely have to, seeing as though it works at times i don't think replacement of all the components as my shop suggested was necessary--
Old Jun 23, 2005 | 01:22 AM
joeysrover's Avatar
i have looked up a potential culprit, a "3-way pressure switch failure".
has anyone else had this problem?
Old Jun 24, 2005 | 03:19 PM
nomadix's Avatar
4th Gear
joeysrover:
thanks for the reply:
Uppon more research I draw your attention to : http://www.rangerovers.net/repairdet...lendmotor.html
this guy has put together a fine site on the HSE- hope this helps- i'll post more as soon as I get to the cure
peace:
simonb1977
Jun 29, 2011 01:23 AM
nuno
May 27, 2007 10:28 AM
navysar
Apr 30, 2007 07:57 PM
werldcup
Mar 10, 2007 06:54 PM
chrisusvi
Feb 27, 2006 02:36 AM
