After battery change write up
Old Dec 17, 2011 | 10:32 AM
richardw's Avatar
6th Gear
Default Still having trouble please help if you can...
My battery died of old age. I replaced it and the resetting all went well except for the radio. I put the key code in instead of the radio code.... and kept doing it!
By the time I realised the error the radio wouldn't let me try to put it right anymore. No matter how long I held in the BND button it will not give me the CODE IN screen. I have four hyphens displayed and nothing else. I tried disconnecting the battery and doing it all over again but the hyphens are all I get. What do I need to do to get the radio working again please?
richardw
Old Dec 30, 2011 | 11:54 AM
rover_rescue's Avatar
7th Gear
Default four dashes
Richard,
Put the key in the ignition, roll down the driver window (to not get locked out), turn the ignition to "on" without starting the car, turn the power to the radio on, and let sit for over 1 hour.
Make sure the accessories are off so you do not drain the battery.
When you return, hold the bnd button for a few seconds, and the code screen will pop up.
Enter the code, and the radio should turn on.
Enjoy!
Old Dec 31, 2011 | 10:27 AM
richardw's Avatar
6th Gear
Default Thank you
Originally Posted by rover_rescue
Richard,
Enjoy!
Thank you, I am trying it right now - 50 minutes to go...
richard
Old Dec 31, 2011 | 03:43 PM
7th Gear
Did it work?
Old Jan 1, 2012 | 05:57 AM
richardw's Avatar
6th Gear
Did it work?
Sadly, no. The code in did appear as you said but when I put in the code it displayed the code but the radio did not come on.
richard
Old Jan 8, 2012 | 06:06 PM
richardw's Avatar
6th Gear
Any more thoughts?
richard
Old Jan 9, 2012 | 05:46 AM
7th Gear
sounds like you have the wrong code...
Old Jan 10, 2012 | 06:31 AM
richardw's Avatar
6th Gear
That fixed it! It would seem that the car has had a second radio fitted and tucked behind the card in the user manual wallet was another card. Tried the number on that and hurray!
Thank you very much indeed.
richard
Old Jan 10, 2012 | 09:47 AM
7th Gear
Glad I could help, just went through the exact same scenario a few weeks ago...
Old Jan 11, 2012 | 04:56 AM
richardw's Avatar
6th Gear
There is no substitute for experience!
richard
