air suspension
Need some help! Whenever I park my front driver side deflates all the way to the stopper. It seems to be normal when it is running. Do I have a leak?
RE: air suspension
Yes You've got leakage.
Most of these problems are in the Air Suspension Valve Block, but furst check air springs, pipes and then if everything is OK check the valve block. I hope to help you with this info . |
RE: air suspension
coil spring conversion time!!
RE: air suspension
Turns out I just had a leak in the air hose going from the air bag to the valve block. The dealer had a splice connector where you just cut out the bad peice and push the hose into the connector. Only cost me 28 bucks. So be sure to check for the cheap fixes before you go out and buy an 6 or 7 hundred dollar conversion kit. Thanks guys. Later.
