air suspension
Old Jun 17, 2005 | 10:18 PM
37chambers's Avatar
Default air suspension
Need some help! Whenever I park my front driver side deflates all the way to the stopper. It seems to be normal when it is running. Do I have a leak?
Old Jun 20, 2005 | 10:25 AM
Diag11's Avatar
6th Gear
Default RE: air suspension
Yes You've got leakage.
Most of these problems are in the Air Suspension Valve Block, but furst check air springs, pipes and then if everything is OK check the valve block.
I hope to help you with this info .
Old Jun 20, 2005 | 03:49 PM
mikemeyer0's Avatar
coil spring conversion time!!
Old Jul 1, 2005 | 07:37 PM
37chambers's Avatar
Turns out I just had a leak in the air hose going from the air bag to the valve block. The dealer had a splice connector where you just cut out the bad peice and push the hose into the connector. Only cost me 28 bucks. So be sure to check for the cheap fixes before you go out and buy an 6 or 7 hundred dollar conversion kit. Thanks guys. Later.
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
catchthebig1
Sep 24, 2010 11:57 AM
tripz
Jan 4, 2007 05:58 PM
