Cranks but won't start. PLEASE HELP!!!
2004 RR HSE, I disconnected the battery while changing the fuel filter. Now after I reconnected the battery one day later it will not start. no fire no fuel.
Please advise and thanks in advance. |
Does it turn over?
Well if it cranks, you need to check the fuel pressure. This a little like the fuel pump. The L322s use ignition coils on ever cylinder I believe, so I doubt that is the issue. It could be a crank shaft position sensor, but I would test the fuel pressure first before throwing parts at it.
Originally Posted by wilson96rr
(Post 196007)
Does it turn over?
Originally Posted by LRScott
(Post 196153)
i'm not getting 12v to the fuel pump relay. Any suggestion. Thanks very much. |
Did you check the fuse for the fuel pump with a meter?
