Cranks but won't start. PLEASE HELP!!!
Old Sep 1, 2010 | 10:02 PM
07841tb's Avatar
3rd Gear
Default Cranks but won't start. PLEASE HELP!!!
2004 RR HSE, I disconnected the battery while changing the fuel filter. Now after I reconnected the battery one day later it will not start. no fire no fuel.
Please advise and thanks in advance.
Old Sep 2, 2010 | 05:32 AM
wilson96rr's Avatar
Does it turn over?
Old Sep 2, 2010 | 11:42 PM
LRScott's Avatar
Well if it cranks, you need to check the fuel pressure. This a little like the fuel pump. The L322s use ignition coils on ever cylinder I believe, so I doubt that is the issue. It could be a crank shaft position sensor, but I would test the fuel pressure first before throwing parts at it.
Old Sep 3, 2010 | 07:03 AM
07841tb's Avatar
3rd Gear
Originally Posted by wilson96rr
Does it turn over?
Yes, it does crank but will not start.
Old Sep 3, 2010 | 07:07 AM
07841tb's Avatar
3rd Gear
i am getting ignition fire to the coils, checked the crank sensor, it's throwing outr references as you crank it ( checked w/ volt meter).
i'm not getting 12v to the fuel pump relay. Any suggestion.
Thanks very much.
Old Sep 3, 2010 | 08:35 PM
wilson96rr's Avatar
Did you check the fuse for the fuel pump with a meter?
dmatranga
Feb 5, 2013 12:27 AM
jrkstore43
Sep 28, 2012 04:16 PM
texmanmoore
Dec 5, 2010 12:45 PM
J dog
Sep 8, 2008 07:46 AM
unco
Jan 28, 2007 02:56 AM
