diagnostic code PO1708
any ideas on what this code means?
1997 range rover hse 4.6 |
RE: diagnostic code PO1708
Are you sure that is the right code? I can find that specific one. Please check and let us know. Thanks..:)
Fault codes:
• P0130 - Oxygen sensor circuit slow response, upstream sensor bank A • P0136 - Oxygen sensor circuit slow response, upstream sensor bank A • P0150 - Oxygen sensor circuit slow response, upstream sensor bank B • P0156 - Oxygen sensor circuit slow response, upstream sensor bank B • P0131 - Oxygen sensor circuit low voltage, upstream sensor bank A • P0151 - Oxygen sensor circuit low voltage, upstream sensor bank B • P0137 - Oxygen sensor circuit low voltage, downstream sensor bank A • P0157 - Oxygen sensor circuit low voltage, downstream sensor bank B • P0132 - Oxygen sensor circuit high voltage, upstream sensor bank A • P0152 - Oxygen sensor circuit high voltage, upstream sensor bank B • P0138 - Oxygen sensor circuit high voltage, downstream sensor bank A • P0158 - Oxygen sensor circuit high voltage, downstream sensor bank B • P0133 - Oxygen sensor circuit slow response, upstream sensor bank A • P0153 - Oxygen sensor circuit slow response, upstream sensor bank B • P0139 - Oxygen sensor circuit slow response, downstream sensor bank A • P0159 - Oxygen sensor circuit slow response, downstream sensor bank B • P1138 - Oxygen sensor problem with switching lean, sensor(s) for bank A • P1158 - Oxygen sensor problem with switching lean, sensor(s) for bank B • P1137 - Oxygen sensor problem with switching rich, sensor(s) for bank A • P1157 - Oxygen sensor problem with switching rich, sensor(s) for bank B • P1139 - Oxygen sensor circuit switching period too long bank A • P1159 - Oxygen sensor circuit switching period too long bank B • P1171 - System too lean bank A and bank B • P1172 - System too rich bank A and bank B • P0171 - System too lean bank A • P0174 - System too lean bank B • P0172 - System too rich bank A • P0175 - System too rich bank B • P1185 - Oxygen sensor heater circuit open circuit, upstream sensors • P1186 - Oxygen sensor heater circuit short circuit, upstream sensors • P1187 - Oxygen sensor heater circuit inferred open circuit, upstream sensors • P1188 - Oxygen sensor heater circuit high resistance, upstream sensors • P1189 - Oxygen sensor heater circuit inferred low resistance, upstream sensors • P1190 - Oxygen sensor heater circuit low resistance, upstream sensors • P1191 - Oxygen sensor heater circuit open circuit, downstream sensors • P1192 - Oxygen sensor heater circuit short circuit, downstream sensors • P1193 - Oxygen sensor heater circuit inferred open circuit, downstream sensors • P1194 - Oxygen sensor heater circuit high resistance, downstream sensors • P1195 - Oxygen sensor heater circuit inferred low resistance, downstream sensors • P1196 - Oxygen sensor heater circuit low resistance, downstream sensors • P0420 - Catalyst efficiency is low, bank A • P0430 - Catalyst efficiency is low, bank B • P1440 - Purge valve stuck open. • P0442 - Evaporative loss control system - small leak • P0448 - Evaporative loss control system - major leak • P0496 - Evaporative loss control system - major leak • P0446 - Purge canister closure valve information • P1447 - Purge canister closure valve - poor performance • P0451 - Fuel tank pressure sensor poor performance fault • P0452 - Fuel tank pressure sensor low range fault • P0453 - Fuel tank pressure sensor high range fault • P0441 - Purge valve flow fault • P0443 - Purge valve open or short circuit • P1775 - Gearbox has signalled a fault condition to the ECM • P1776 - Gearbox ignition retard request duration fault • P1777 - Gearbox ignition retard request line fault • P0327 - (LH bank signal less than the threshold value determined from the ECM model above 2200 rpm) • P0328 - (LH bank signal greater than the threshold value determined from the ECM model above 2200 rpm) • P0332 - (RH bank signal less than the threshold value determined from the ECM model above 2200 rpm) • P0333 - (RH bank signal greater than the threshold value determined from the ECM model above 2200 rpm) Injector 1 • P0201 - Open circuit • P0261 - Short circuit to ground • P0262 - Short circuit to battery supply Injector 2 • P0202 - Open circuit • P0264 - Short circuit to ground • P0265 - Short circuit to battery supply Injector 3 • P0203 - Open circuit • P0267 - Short circuit to ground • P0268 - Short circuit to battery supply Injector 4 • P0204 - Open circuit • P0270 - Short circuit to ground • P0271 - Short circuit to battery supply Injector 5 • P0205 - Open circuit • P0273 - Short circuit to ground • P0274 - Short circuit to battery supply Injector 6 • P0206 - Open circuit • P0276 - Short circuit to ground • P0277 - Short circuit to battery supply Injector 7 • P0207 - Open circuit • P0279 - Short circuit to ground • P0280 - Short circuit to battery supply Injector 8 • P0208 - Open circuit • P0282 - Short circuit to ground • P0283 - Short circuit to battery supply All injectors • P0170 - High leak rate detection • P0300 to P0308 - Misfire detected excess emissions - blocked or restricted injector • P0300 to P0308 - Misfire detected catalyst damage - blocked or restricted injector the air flow into the engine. • P0505 - Blocked IACV valve - rpm error high or low • P1510 - Short circuit to battery supply - opening winding • P1513 - Short circuit to ground - opening winding • P1514 - Open circuit - opening winding • P1553 - Short circuit to battery supply - closing windings • P1552 - Short circuit to ground - closing winding • P1551 - Open circuit - closing winding • P1129 - Front heated oxygen sensors transposed Upstream sensor LH bank - electrical (NAS only) • P0130 - Stoichiometric ratio outside operating band • P0132 - Short circuit to battery supply • P0134 - Open circuit Downstream sensor LH bank - electrical • P0136 - Stoichiometric ratio outside operating band • P0137 - Short circuit to battery supply • P0138 - Short circuit to ground or chemical shift down • P0140 - Open circuit Upstream sensor RH bank - electrical (NAS only) • P0150 - Stoichiometric ratio outside operating band • P0152 - Short circuit to battery supply • P0154 - Open circuit Downstream sensor RH bank - electrical • P0156 - Stoichiometric ratio outside operating band • P0157 - Short circuit to ground • P0158 - Short circuit to battery voltage • P0160 - Open circuit Upstream sensors aged (NAS only) • P0133 - Upstream sensor aged - Period time too short LH bank • P0133 - Upstream sensor aged - Period time too long LH bank • P0153 - Upstream sensor aged - Period time too short RH bank • P0153 - Upstream sensor aged - Period time too long RH bank • P1170 - Upstream sensor aged - ATV adaption too lean LH bank • P1170 - Upstream sensor aged - ATV adaption too rich LH bank • P1173 - Upstream sensor aged - ATV adaption too lean RH bank • P1173 - Upstream sensor aged - ATV adaption too rich RH bank Sensor Heater faults • P0135 - Upstream heater LH bank - Short circuit (NAS only) • P0135 - Upstream heater LH bank - Open circuit (NAS only) • P0141 - Downstream heater LH bank - Short circuit • P0141 - Downstream heater LH bank - Open circuit • P0155 - Upstream heater RH bank - Short circuit (NAS only) • P0155 - Upstream heater RH bank - Open circuit (NAS only) • P0161 - Downstream heater LH bank - Short circuit • P0161 - Downstream heater LH bank - Open circuit • P0420 - Catalyst efficiency deteriorated LH bank • P0430 - Catalyst efficiency deteriorated RH bank • P12 |
How do you get the fault codes off of the car's computer?
If it is a 97, he had to use a scanner, his truck is an OBD2.
I am wondering if you used a noncompatiable scanner that is not reading the Rover codes properly. Mike |
P1708 is Transfer Box link short circuit.
PO1708 may have been a ttype-o |
