diagnostic code PO1708
Old Jan 3, 2006 | 06:28 PM
prsbanker's Avatar
Default diagnostic code PO1708
any ideas on what this code means?
1997 range rover hse 4.6
Old Jan 27, 2006 | 12:24 PM
mcnabj's Avatar
4th Gear
Default RE: diagnostic code PO1708
Are you sure that is the right code? I can find that specific one. Please check and let us know. Thanks..
Old May 17, 2006 | 07:35 AM
CronicJoeBlunt's Avatar
Fault codes:
• P0130 - Oxygen sensor circuit slow response,
upstream sensor bank A
• P0136 - Oxygen sensor circuit slow response,
• P0150 - Oxygen sensor circuit slow response,
upstream sensor bank B
• P0156 - Oxygen sensor circuit slow response,
• P0131 - Oxygen sensor circuit low voltage,
• P0151 - Oxygen sensor circuit low voltage,
• P0137 - Oxygen sensor circuit low voltage,
downstream sensor bank A
• P0157 - Oxygen sensor circuit low voltage,
downstream sensor bank B
• P0132 - Oxygen sensor circuit high voltage,
• P0152 - Oxygen sensor circuit high voltage,
• P0138 - Oxygen sensor circuit high voltage,
• P0158 - Oxygen sensor circuit high voltage,
• P0133 - Oxygen sensor circuit slow response,
• P0153 - Oxygen sensor circuit slow response,
• P0139 - Oxygen sensor circuit slow response,
• P0159 - Oxygen sensor circuit slow response,
• P1138 - Oxygen sensor problem with switching
lean, sensor(s) for bank A
• P1158 - Oxygen sensor problem with switching
lean, sensor(s) for bank B
• P1137 - Oxygen sensor problem with switching
rich, sensor(s) for bank A
• P1157 - Oxygen sensor problem with switching
rich, sensor(s) for bank B
• P1139 - Oxygen sensor circuit switching period
too long bank A
• P1159 - Oxygen sensor circuit switching period
too long bank B
• P1171 - System too lean bank A and bank B
• P1172 - System too rich bank A and bank B
• P0171 - System too lean bank A
• P0174 - System too lean bank B
• P0172 - System too rich bank A
• P0175 - System too rich bank B
• P1185 - Oxygen sensor heater circuit open
circuit, upstream sensors
• P1186 - Oxygen sensor heater circuit short
• P1187 - Oxygen sensor heater circuit inferred
open circuit, upstream sensors
• P1188 - Oxygen sensor heater circuit high
resistance, upstream sensors
• P1189 - Oxygen sensor heater circuit inferred
low resistance, upstream sensors
• P1190 - Oxygen sensor heater circuit low
• P1191 - Oxygen sensor heater circuit open
circuit, downstream sensors
• P1192 - Oxygen sensor heater circuit short
• P1193 - Oxygen sensor heater circuit inferred
open circuit, downstream sensors
• P1194 - Oxygen sensor heater circuit high
resistance, downstream sensors
• P1195 - Oxygen sensor heater circuit inferred
low resistance, downstream sensors
• P1196 - Oxygen sensor heater circuit low
• P0420 - Catalyst efficiency is low, bank A
• P0430 - Catalyst efficiency is low, bank B
• P1440 - Purge valve stuck open.
• P0442 - Evaporative loss control system - small
leak
• P0448 - Evaporative loss control system - major
leak
• P0496 - Evaporative loss control system - major
leak
• P0446 - Purge canister closure valve information
• P1447 - Purge canister closure valve - poor
performance
• P0451 - Fuel tank pressure sensor poor
performance fault
• P0452 - Fuel tank pressure sensor low range
fault
• P0453 - Fuel tank pressure sensor high range
fault
• P0441 - Purge valve flow fault
• P0443 - Purge valve open or short circuit
• P1775 - Gearbox has signalled a fault condition
to the ECM
• P1776 - Gearbox ignition retard request duration
fault
• P1777 - Gearbox ignition retard request line fault
• P0327 - (LH bank signal less than the threshold
value determined from the ECM model above
2200 rpm)
• P0328 - (LH bank signal greater than the
threshold value determined from the ECM model
above 2200 rpm)
• P0332 - (RH bank signal less than the threshold
2200 rpm)
• P0333 - (RH bank signal greater than the
above 2200 rpm)
Injector 1
• P0201 - Open circuit
• P0261 - Short circuit to ground
• P0262 - Short circuit to battery supply
Injector 2
• P0202 - Open circuit
• P0264 - Short circuit to ground
• P0265 - Short circuit to battery supply
Injector 3
• P0203 - Open circuit
• P0267 - Short circuit to ground
• P0268 - Short circuit to battery supply
Injector 4
• P0204 - Open circuit
• P0270 - Short circuit to ground
• P0271 - Short circuit to battery supply
Injector 5
• P0205 - Open circuit
• P0273 - Short circuit to ground
• P0274 - Short circuit to battery supply
Injector 6
• P0206 - Open circuit
• P0276 - Short circuit to ground
• P0277 - Short circuit to battery supply
Injector 7
• P0207 - Open circuit
• P0279 - Short circuit to ground
• P0280 - Short circuit to battery supply
Injector 8
• P0208 - Open circuit
• P0282 - Short circuit to ground
• P0283 - Short circuit to battery supply
All injectors
• P0170 - High leak rate detection
• P0300 to P0308 - Misfire detected excess
emissions - blocked or restricted injector
• P0300 to P0308 - Misfire detected catalyst
damage - blocked or restricted injector
the air flow into the engine.
• P0505 - Blocked IACV valve - rpm error high or
low
• P1510 - Short circuit to battery supply - opening
winding
• P1513 - Short circuit to ground - opening winding
• P1514 - Open circuit - opening winding
• P1553 - Short circuit to battery supply - closing
windings
• P1552 - Short circuit to ground - closing winding
• P1551 - Open circuit - closing winding
• P1129 - Front heated oxygen sensors
transposed
Upstream sensor LH bank - electrical (NAS only)
• P0130 - Stoichiometric ratio outside operating
band
• P0132 - Short circuit to battery supply
• P0134 - Open circuit
Downstream sensor LH bank - electrical
• P0136 - Stoichiometric ratio outside operating
band
• P0137 - Short circuit to battery supply
• P0138 - Short circuit to ground or chemical shift
down
• P0140 - Open circuit
Upstream sensor RH bank - electrical (NAS only)
• P0150 - Stoichiometric ratio outside operating
band
• P0152 - Short circuit to battery supply
• P0154 - Open circuit
Downstream sensor RH bank - electrical
• P0156 - Stoichiometric ratio outside operating
band
• P0157 - Short circuit to ground
• P0158 - Short circuit to battery voltage
• P0160 - Open circuit
Upstream sensors aged (NAS only)
• P0133 - Upstream sensor aged - Period time too
short LH bank
long LH bank
• P0153 - Upstream sensor aged - Period time too
short RH bank
long RH bank
• P1170 - Upstream sensor aged - ATV adaption
too lean LH bank
too rich LH bank
• P1173 - Upstream sensor aged - ATV adaption
too lean RH bank
too rich RH bank
Sensor Heater faults
• P0135 - Upstream heater LH bank - Short circuit
(NAS only)
• P0135 - Upstream heater LH bank - Open circuit
(NAS only)
• P0141 - Downstream heater LH bank - Short
circuit
• P0141 - Downstream heater LH bank - Open
circuit
• P0155 - Upstream heater RH bank - Short circuit
(NAS only)
• P0155 - Upstream heater RH bank - Open circuit
(NAS only)
• P0161 - Downstream heater LH bank - Short
circuit
• P0161 - Downstream heater LH bank - Open
circuit
• P0420 - Catalyst efficiency deteriorated LH bank
• P0430 - Catalyst efficiency deteriorated RH bank
• P12
Old May 22, 2006 | 02:10 AM
djhuetinck's Avatar
How do you get the fault codes off of the car's computer?
Old May 22, 2006 | 11:31 AM
If it is a 97, he had to use a scanner, his truck is an OBD2.
I am wondering if you used a noncompatiable scanner that is not reading the Rover codes properly.
Mike
Old May 22, 2006 | 02:27 PM
Landzu's Avatar
P1708 is Transfer Box link short circuit.
PO1708 may have been a ttype-o
seanyh
May 2, 2013 08:10 AM
c670809
Dec 11, 2012 10:48 AM
sayeedA
Nov 15, 2011 11:02 PM
acegt1
Feb 25, 2009 12:53 PM
