EAS -> Spring question
So, I'm thinking of swapping over the EAS to a spring setup. I'm looking at the options, and I'm liking the 3" over stock one. My question is, is that 3" higher than the standard height, the access height, the raised height, etc?
Try Atlantic British they have a FAQ section, if its not there they will help you via email.
I do not know the definative answer to that one, especially since you do not say who makes the spring. As a general it would be 3" over the standard height which would be approximately 1" taller than offroad height.
If you are going that way then I would plan on buying some new tires to fill the big opening. |
You may also have to purchase new shocks as the OEM ones may not accommodate the height difference. Just something to verify before you go ahead with the 3".
In case you haven't already considered it... ride quality will be decreased with the 3" lift. |
Originally Posted by ldivine
(Post 125966)
In case you haven't already considered it... ride quality will be decreased with the 3" lift. And as for tires, I've already got 32" on the truck so I'll probably just go with the extra 1/2" to the 33" tires. |
First, lets try a year and model?
Second, why get rid of the EAS? Not knowing what you are driving, but why a 3" lift, are you ready for all the extra stuff to change? What ever you do, do not buy a set of Ranchos, they are they worst piece of crap you can throw on any Rover. |
Originally Posted by Disco Mike
(Post 126095)
most people change to spring due to dealers wanting a fortune to repair the aging system. at the very least go with something like a MARS until you can correct the real issue, a leak.
I guess that is a question too. Is the EAS broken or do you just want to do something different since you are concerned about failure out on the trail?
I have seen some others do an extended level sensor arm that gives you an extra 2" of lift when you need it, it is being called super extended off road mode or something like that. I love the EAS and I know they can be expensive but if you are willing to wrench then it is not that bad. |
The truck is a 98 RR HSE 4.6
Switching to spring because I finally started having issues with the front left air bag, and I think my compressor is starting to show it's age as well. I'd love to keep the EAS setup, but I'd also like to go a little bigger. If I could find an aftermarket air bag that would give me another inch or two, I'd be happy with that. And the reason I was thinking of Ranchos is because I used them on my S10 build and liked them, I'm really open to any shock suggestions if I go that route though. |
