help, knocking noise on engine,,,,
Old Sep 11, 2006 | 09:21 AM
tobob1's Avatar
5th Gear
Default help, knocking noise on engine,,,,
i have a 97 range rover 4.0 se , i only have it for 1 month and since last week everytime i use it i hear a knocking noise on the right side of the engine ,,
Old Sep 11, 2006 | 11:31 AM
Default RE: help, knocking noise on engine,,,,
How many miles on the engine and when do you hear this knocking noise, hot, cold, all the time, under load give us more information?
Mike
Old Sep 12, 2006 | 05:48 AM
tobob1's Avatar
5th Gear
it has 103,xxx miles and i only hear it when the engine is already warmed up,, coz when i start the engine in the morning it sounds good but after i drove the car it sounds like a diesel engine,,
Old Sep 12, 2006 | 11:30 AM
ORIGINAL: tobob1
At that mileage, it is hard to say, could be a rod knock, rocker arm/ lifter problem. What ever it is, don't continue to allow it to happen, really need to let a shop look at it.
Mike
Old Sep 13, 2006 | 06:22 AM
tobob1's Avatar
5th Gear
i saw a post in this forum, that they just put a valvemedic treatment or do the engine flush and it mkes their engine quiet,, is it really a good idea or can it give more problem to the engine??
Old Sep 13, 2006 | 11:32 AM
ORIGINAL: tobob1
To do an engine flush will not hurt an engine, but if you have a mechanical internal engine problem, it will make it more obvious. For the most part this is considered a good thing to do once in awhile to keep your engine free os sludge build up and the problems this can cause.
Mike
Old Nov 27, 2006 | 02:11 AM
moneypit37's Avatar
The post you refered to was one where Mike and I cover most all possibilities of a "TICK". I took the entire top and bottom ends apart on my engine and cleaned it by hand. The valvemedic was temporary at best to at least thin the oil enough to suck through the plugged screen. I also had a different tick that only started after the engine warmed up. This ended up being the passenger side cat.
mellyagaunce
Sep 19, 2008 09:16 AM
apancho
Jan 22, 2007 12:47 PM
mr.47
Sep 25, 2006 09:01 PM
tobob1
Sep 11, 2006 09:14 AM
disco1
Mar 3, 2006 10:29 AM
