I think my fuel pump just quit
Driving along on the freeway and just lost power. It will crank and spark but does not seem to get fuel. The traffic is too loud to listen for the pump so I will check further tonight once the tow truck comes and gets me. I will also have a fuel pressure guage to help diagnose as well if I ever get home.
Okay here is what it was. I checked the fuel pressure and there was none, checked that I had spark so I knew that the CPS was working. Changed the fuel filter and checked all the lines. I almost ordered a new pump but then thought I should check all the fuses again. I found a small hairline crack in the fuel pump fuse under the hood. Replaced it and then found the problem. The bearing on the alternator was shot and caused the fuse to blow for the pump somehow. Replaced the alternator and all is well and back on the road.
It makes sense to sit back and think about it before just buying parts.
Good to hear its back on the road! and good attention to detail .
Glad you are back up and running.
For as much crap as people give the P38 for troubles I have found that it is fairly easy to work on and not that expensive, all you have to think about and so some logical deduction.
Thanks guys for the help.
You mean the ignition coil? Or it is something else? My car is experiencing the same problem just last night.
