just bought a 2000 HSE
Old 07-09-2006, 04:04 PM
slackwaresupport's Avatar
Default just bought a 2000 HSE
hey guys, i have a few questions.. just got a HSE. it didnt come with an owners manual. soo here goes.:
1. my radio stays on when i cut my key off., and the navigation computer still has a power light.
2. where do i get the navigation cds for cheap??
3. are there anythings i need to know about the 2000 HSE??
Old 07-10-2006, 11:55 AM
Default RE: just bought a 2000 HSE
anyone????
Old 07-10-2006, 01:28 PM
bangbang's Avatar
5th Gear
Thats normal for the nav radio to stay powered up after the keys off, as for the owners manual and nav cd's look on ebay.
As for concerns keep an eye on the intakes and head gaskets and wheel speed sensors for the abs system can give you problems
Old 07-10-2006, 01:57 PM
moneypit37's Avatar
Check with a dealer.
If they can't help you...
Ebay has been a savior for the little parts on my RR.
Search for "Range Rover Navigation"
I saw several OEM nav cd's listed in Ebay Stores.
Old 07-10-2006, 02:15 PM
welp, i talked to my dealer, and they said it would be cheaper to buy the cds from navtech, and i called them, its $200 for all of US and canada..
so im thinking of just ripping the factory out, and having say a tomtom custom installed, color, and voice, lots better than the stocker
Old 07-10-2006, 02:19 PM
also, im guessing the radio will finally turn itself off??
Old 07-10-2006, 02:33 PM
moneypit37's Avatar
The radio will probably stay on and the windows will work until you open a door.
These are standard fade out procedures for high end vehicles.
I saw a bunch of different NavTech cds on Ebay for $39-$59 each.
If you search on some different word combo's you may find some up for auction that are going for pennies.
Old 07-10-2006, 02:39 PM
i thought that it would go off on the door opening, but it doesnt, and it looks like someone has installed a stereo in it before, so they probally fubared something, and the radio kinda hangs a little out, and will not "click" back in..
Old 07-10-2006, 02:53 PM
moneypit37's Avatar
If the previous stereo was a Do It Your Selfer install they may have hooked the constant on wire for the memory up to the power that should be switched with the key.
If it is the factory deck; just don't touch it with the key out! Mine locked up and I had to go to the dealer for the code.
So do you just turn it off when you get out?
Old 07-10-2006, 02:59 PM
so on the stereo uninstall, is it just the "ford pulling pins" from the front?? is there anything else that locks it in ????
Quick Reply: just bought a 2000 HSE
