p38 front prop missing
Hi all my mate has just bought a p38range on a 01 plate on a whim. Went to service it for him only to find that the transmission rad was leaking and the main concern, that the front drive shaft is not there at all, someone has removed it. Has any one any ideas why someone would have removed it before we get a new one and replace it to find that it is going to grind something to a pulp.
many thanks in advance
steve
steve
They might have removed it because of a VC issue, or they were to cheap to buy a new drive shaft. Driving around without a drive shaft is generally inadvisable. It usually damages the transfer case and viscous coupling. It can be done in an emergency though or if the vehicle needs to be towed with 2 wheels still on the road.
It could be what Scott said or it could be that someone thought they would get better MPG by removing it since it is 4WD all the time. I am hearing of more missing front shafts since gas prices went up the past couple of years. The VC may give issues when it needs the traction though depending on how long it has been with out one.
People remove the front shafts not only on Rovers, but on Jeeps that have the AW4 transmission. I think it does more harm than good in doesn't make a lick of sense to me. Hopefully for the OP it is a gas saving measure and not a VC problem.
As we've discussed before on this issue, the rear diff is designed to work in concert with the front diff (share torque distribution), using rear drive only for lengthy periods may put undue stress on the rear diff. Do I think this would cause failure? Unlikely, but more wear and tear no doubt.
Sorry I do not know, and it is about -1F outside so I am not willing to go out and measure it for you. If you call Roverland parts or just about any other wrecking yard that has Rovers they will be able to get you one. If you want custom you can call Tom Woods or go to a local shop and they will measure for you and make it.
Hi all just an update. got a prop and fitted it, only to find a whine comeing from the car, and got axle wind up, narrowed it down to the vc, changed the vc and changed oil in diffs, front all clean, rear found bit of teeth and a roll pin about 20mm x 4mm and still got the whine when foot is take off the accelarator and engine braking takes over. all ideas on where the whine could be coming from greatly recieved
cheers steve
cheers steve
