Range rover P38 weird Oil leak problem
Hello,
I would need an advice about an oil leak I have on my Range Rover P38 4.0 SE (year 1997).
2months ago, I had to changethe intake gaskets and the head gaskets because of coolant leak, in a independent Land rover repair shop. [/align][/align]Since then I have to add a quart of motor oil every 200 miles. (I didn't have any oil leak before)
[/align]The thing is, that I have no visible oil leak, nothing on the floor, and no black smoke.[/align]
Iwent to Land rover Cincinnati for them to check the oil leak butthey told me that they don't know why I'm losing so much oil, [/align]because they couldn't see any visible leak.
[/align]I've been told if there was a piston problem, I should have black smoke when driving my car, but I don't have that.[/align][/align]Is there something that the mechanic who changed the head gaskets could have done wrong ? I was thinking of the valve stem seals maybe. [/align]
Thanks a lot for your help.
Pat3d[/align]
Pat3d[/align]
rear main seal is the output shaft of the motor going to the tranny. Rear main seals should leave a puddle, as they're so low on the block, there's not much chance for the oil to dry up as it drips down the block.
I suppose it is possible that you have a mis-seated rear main seal...although that shouldnt have been effected by the head/IMG work...but the seal only gets distrubed while driving, which explains why you see no puddle..but I'm not sure.
if you got oil that far back, then lookin wont tell you anything. the whole underbody of your car will be soaked. to check if its the rear main, you need to be under the car, on the front of the trans, youll see a little circular plate on the bellhousing. take it off and look up there with a light, watch out as you take it off if thats what it is as you might get a shower. but the rear main will show up as oil splattered all over the inside on the bellhousing, not just it wet, but like it was flung off from the middle.
[/align]
on
It is nearly impossible to loss that much oil with out seeing a lot of oil under the truck, all the way back to the rear bumper.
Look at your repair bill and see if the shop replaced the intake manifold gasket, a $50 plus part, if not, that is your problem.
