-   General Range Rover Discussion - Archived (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/)
-   -   Range Rover Runner Boards, Side Steps (https://landroverforums.com/forum/general-range-rover-discussion-archived-19/range-rover-runner-boards-side-steps-43159/)
davidtudor1 Aug 22, 2011 08:27 AM
Hi
Anybody out there had any problems with runner boards, side steps on the Range Rover TDV8?
These are just stuck and will not come out at all, the light on the switch in the roof trim for the manual override is not illuminated.
I have code read with IDS and its has 35 faults, but will not erase, I think it could be a fuse or wiring problem. Any help would be appriceated.
Rovin4life Aug 22, 2011 08:47 PM
try disconnecting the ecu on the passenger side footwell trim.
davidtudor1 Sep 20, 2011 10:42 AM
Hi
The ECU disconnect did not work, I also noticed the manual overide button in the headlining near the sunroof switch, the light is not working on that.
The side steps are just not moving at all.
Rovin4life Sep 21, 2011 07:47 AM
Were they actually programmed to the vehicle.
They have to be programmed with Sdd to get it to work.
davidtudor1 Sep 22, 2011 03:05 AM
Hi
Yes there are programmed, they worked perfectly for years, this is a 2007 vehicle, and suddenly they just stopped working and are stuck in.
Rovin4life Sep 23, 2011 07:52 AM
is it seeing the door open switch, is it getting the signal to open, or can they be jumped and operated remotely.
davidtudor1 Sep 30, 2011 06:24 AM
The door switch seems ok, it puts the interior lamps on and off.
We have found a 10amp fuse under the bonnet blown and it just keeps blowing, it is in the fuse box under the bonnet which has a plastic lid bolted on top, we tried to disconnect both steps and the fuse still blows, we cannot locate thou the ECU module for the side steps.
Also today the RH side step just came out and stayed there, will not move now, it is just out and the LH is fixed in.
Rovin4life Sep 30, 2011 09:16 AM
find out what number the fuse is and from there get a wiring diagram to find out what it goes to and if it blows constantly, disconnect everything on that circuit one at time to find out what is causing it to blow. if possible buy a 10 amp circuit breaker so it will reset and you don't have to buy new fuses.
davidtudor1 Nov 22, 2011 04:02 AM
Side Steps, Running Boards
Any idea where the side step/running board module is located?
Rovin4life Nov 22, 2011 08:38 AM
its on the passenger side below the dashboard on the side of the a pillar.
