Shaking while driving
Old 10-28-2013 | 01:32 PM
Bassmaster's Avatar
Lol I've always been a fan of PB blaster. I'll try it and let you know how it goes
Old 10-28-2013 | 04:33 PM
Bassmaster's Avatar
What's the rod that connects directly from wheel to wheel in the front? I noticed that looks like it's shot but I'm not sure what its called.
Old 11-02-2013 | 03:42 PM
eloteq's Avatar
Is your front prop shaft on or been taken off? ;Last year I took my front prop shaft off to get home after a UJ failure. I had terrible death wobbles 50 mph and above; it was very scary.
I found out that the front axles is driven ands thus the tracking is toe out. However when the prop is not present (non driven) you need a bit of toe in.
Other things I found that contributed to the symptoms was: Panhard Rod bushes shot, worn ball joints on drag link & steering link, a worn wheel bearing (mine felt ok till I dissembled the hub & it was shot), Hockey Stick Suspension Arm bushes (mine were blue polybush which are too soft for the RR so replace with OEM Rubber).
Also, if you have 18" wheels these cause wobbles. Whereas the 16" don't
All this finally cured the wobbles.
Old 11-02-2013 | 06:36 PM
Bassmaster's Avatar
I do have 19" wheels instead of 16". And there is something missing under the car that is supposed to be attached the the driver side front wheel. I cants tell what it's supposed to go to. And I saw the bushings on my front stabilizer bar look shot.
Bassmaster's Avatar
What's the toe?
Old 11-06-2013 | 06:37 PM
Bassmaster's Avatar
Where could I find the front prop shaft?
Old 11-13-2013 | 05:38 AM
Bassmaster's Avatar
The car now like wobbles or limbs is only way I can describe it at low speeds. Could this just be an alignment issue?
Bordenaro
04-02-2015 07:42 AM
CrimsonRavyn
02-26-2012 09:40 PM
SteveOPA
01-31-2007 12:00 PM
discovery125
04-07-2006 04:27 PM
jmerrill
04-04-2006 06:37 PM
Quick Reply: Shaking while driving
