Windows, sunroof and mirrors are inop!
So the other day i got in my car and none of the windows would roll down. I checked all fuses and found none to be blown. I searched and found something about the window ecu but heard two different locations. One said under the center console, Im assuming the actual window switch panel is what the person is talking about. Then also heard that it was behind glovebox. The window switch panel has obviously had stuff spilled on it by its sticky texture but nothing recently to my knowlege. Do you all think the swithc panel is the culprit? Im sure its not cheap at all since it s a land rover. Thanks for any and all help it is greatly appreciated, im getting tired of not having windows and a sunroof.
There is what is called a Center Console Switch Pack Outstation --attached to the back side of the bezel on your console that houses the switches. If there was any liquid that found its way into the internals of the switches, or this outstation ---then circuit failure will occur and you must replace the outstation/switch pack unit.
regards,
Geoman
www.eurotekapg.com
regards,
Geoman
www.eurotekapg.com
excellent thank you very much! So just to make sure im clear on this, the entire window switch panel needs to be replaced? Would you by any chance know of where i can find one other than the dealer? As im sure they are very expensive from land rover. I've been looking on ebayh but all i can find are the actual individual switches. Thanks again for the help i figured i would have to get a new panel but just wanted to make sure!
