08 range sport supercharge hard starting
My 08 is hard starting sometimes throughout the day. Almost like it's not getting fuel but it eventually starts. Any ideas?
Thank you |
Check the fuel pump relay under the hood in engine compartment.
Switch it with one labeled SM(starter motor). If the starter starts acting up you know it was the relay. I had similar issue, switched the relay and both starter and pump worked fine for months before selling the LR3(same basic system as a sport). |
Thank you
QUOTE=abran;553764]Check the fuel pump relay under the hood in engine compartment.
Switch it with one labeled SM(starter motor). If the starter starts acting up you know it was the relay. I had similar issue, switched the relay and both starter and pump worked fine for months before selling the LR3(same basic system as a sport).[/QUOTE] |
